Since changing my tyres a couple of weeks ago to Dunlop Roadsmart 3s, I've noticed a handlebar wobble from about 40mph and above. Yesterday this was more noticeable on a ride to Sheffield and back yesterday c.70mph for an hour at a time.
Today I checked the front end thinking maybe the forks rotated slightly. Loosened the axle, fork brace, lower two triple clamp bolts, then re-tightened starting at the bottom and doing the fork brace last. What I discovered is the front axle leaves a small millimetre gap between the fork leg and the spacer on the clutch side. (Pic below).
Doesn't seem to matter how much I tighten the axle the gap won't close, but I can press the fork in at the bottom to close the gap. Thinking I need to loosen the axle off again, maybe remove the fork brace then re-tighten.
Oh, I also noticed on my way home from work the clocks read 34,000 miles before I set off
