Author Topic: What have you done with your V-Strom today?  (Read 1395320 times)
0 Members and 6 Guests are viewing this topic.
Offline hotbulb
  • Bike: DL650 L4
« Reply #7620 on: June 05, 2017, 22:35:16 »
Unfortunately, it happens! Commiserations   :groan:
« Reply #7621 on: June 05, 2017, 22:53:47 »
Spent a few minutes harmonising the super cheapo additional lighting. As those who know, know they have three modes that are called for sequentially each time they are switched on.
What I didn't know when I fitted them and rode off for the Alright My Handsome tour" was that they were out of sync. This resulted in  at first switch on the right side flashing the left not. 2nd switch on gave both on although one was on main and the other on dip, and 3rd switch on right side on and left flashing. So then no wonder more than usual canners made way for me  in busy traffic. I was aware of the flashing mode but as I only checked the left side I did not realise the right side was flashing.
So here's question for those with experience with these lights. I can see the chip that needs surgery but does it matter what mode it is in when the part is extracted or does that chip only affect the flasher circuit.
« Reply #7622 on: June 05, 2017, 23:00:19 »
Sorry to hear that Jeff in Wales, but at least you're not injured.
Offline Jeff in Wales
  • Bike: DL650 L7
« Reply #7623 on: June 06, 2017, 21:40:56 »
Didn't ride it in these winds!
Fitted some bobbins / cotton reels. Got them from SportsBikeShop. The supplied M8 cap head bolts wouldn't screw into the swing arm mountings, seems to be different thread pitch. Found a couple of spare bolts with correct pitch.
No problem lifting bike up on stand, was a bit apprehensive given it's weight.
Gave it a rinse down after that - got a bit mucky yesterday during the downpours.
Offline Froglodyte
« Reply #7624 on: June 06, 2017, 23:18:06 »
Doesn't  matter what mode it's in. Once  you  take the chip out they stay in full mode
« Reply #7625 on: June 07, 2017, 13:26:57 »
Thanks for that Froglodyte.  :thumb:
« Reply #7626 on: June 09, 2017, 21:52:56 »
Took the wee to Orwell's in Ipswich and had them fit Suzuki Sprockets set and chain, Bridgestone A40 rear tyre. In and out in just over an hour. Also bought Oil & filter & plug washer for something to fiddle with next week.
Offline Wayne_202
« Reply #7627 on: June 11, 2017, 22:20:38 »
Did the bikes yearly oil and filter, removed tank and blew out the k&n, acf-50 while the tank was off. Also put another coat of black paint on the bash plate whilst it was off to make it look more presentable.  :fix:
  • Bike: DL650 L7
« Reply #7628 on: June 12, 2017, 17:19:16 »
Fitted new lowering rear suspension links.
Felt a little unsteady unless on flat surfaces and struggled to push the bike backwards whilst seated.
Unnecessary in the event but taking no chances
Lifted / supported rear wheel to jiggle bolts back in
Feels much better now, can push it around whilst seated with comparative ease (in the garage anyway)
Messed up a bit lowering the front. Read advice on forums not to slacken the pinch bolts too much, just a little and then push down on front. But I couldn't get stantions to move despite heaving on the front. Ultimately slackened the bolts a little too much and then stantions went right up to bars.
Had to take weight of front then use wood / hammer to tap forks to new correct height. Lust instructions with rear links suggested only lowering front to max two-thirds of rear. Set them at 15mm.
All done.
No need to trim side stand.
Will do test ride tomorrow.
« Reply #7629 on: June 12, 2017, 22:39:14 »
 :thumb: good, informative set of photos.
Offline Witches70
  • Bike: 2014 Dl 1000
« Reply #7630 on: June 13, 2017, 00:14:00 »
Had a trip over to Maldon Essex this evening to visit Wurzel who has helped me out buy making me some rear foot peg risers for my trip to Geneva on Friday , so Mrs Witches70 can now travel in style & comfort thanks Wurzel  :thumb:
 :ty:
I stand tall,  but I am short
I shout loud, but I am quiet
I ride a DL1000 and Proud.
Offline wurzel
« Reply #7631 on: June 13, 2017, 07:26:07 »
It was nothing, I hope they are adequate and comfy. :)
Offline crabbitoldgit
  • Bike: 2014 V-Strom 1000
« Reply #7632 on: June 13, 2017, 16:03:48 »
Fitted one of Bigpie's rather excellent Aux Fuse Boxes.  :fix:
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #7633 on: June 13, 2017, 16:17:21 »
Nice install, much neater than mine :D under my seat will give people with OCD nightmares for weeks.
« Reply #7634 on: June 13, 2017, 16:44:53 »
Trust me, I'm not that tidy normally. Saw other people getting grief for untidy wiring and thought better of it ;-)
« Reply #7635 on: June 13, 2017, 23:25:28 »
Finished reassembling the bike following the TPS adjustment. Treated it to new brake fluid, cleaned it and reapplied ACF50. Off to Sheffield tomorow so looking forward to seeing if the TPS adjustment has made any difference and to see if the brakes work have firmed up...
Offline Beeroclock
  • Bike: DL650 L7
« Reply #7636 on: June 14, 2017, 11:12:33 »
Bought it :) - thanks for everyones help - much appreciated....
Offline wurzel
« Reply #7637 on: June 14, 2017, 13:23:57 »
Washed it...after a fellow strommer came round and my partner saw how clean his bike was...comments were made.... :icon_batterup: :shrug:
Offline Geordie20
  • Bike: Yamaha FJR 1300
« Reply #7638 on: June 14, 2017, 17:29:59 »
Removed front sprocket cover and cleaned out. I've had the bike just over a year, but haven't got a clue when that was last cleaned out. Interesting to say the least, it was packed solid. Then decided to change clutch fluid. Dealer serviced when I bought the bike allegedly, all I can say is I've never seen brake fluid the colour of coffee before. If this was checked before I got it all I can say is the mechanic must be colour blind. I feel a replacement of brake hoses and fluid coming on and a brake service might be prudent.
Offline Wayne_202
« Reply #7639 on: June 14, 2017, 20:32:00 »
Put my second hand brand new fork brace on. Will take it for a spin after work tomorrow see if it was £23 worth spending. :D
