Author Topic: What have you done with your V-Strom today?  (Read 1395581 times)
0 Members and 19 Guests are viewing this topic.
Offline 2112
« Reply #7560 on: May 11, 2017, 08:44:41 »
I picked my bike up from Ian Bell Motorcycles with it's fresh new Avon Trailriders fitted and a new 42 tooth rear sprocket. After several steady miles scrubbing the new tyres in I gently upped the pace and before long there was much footpeg dragging fun ! I love these tyres, really fast turn in and I even got to try them out on some gravel and they didn't budge, which is nice. Full report to follow when I get some miles on them in the tyre section. The 42 tooth rear is a much nicer gearing for the Vee (only 2.5% difference in case you were wondering over the stock 41 tooth item) in my opinion. I had a 43 tooth rear on my last one and that was probably a bit too much, although it accelerated like a bat out of hell ! Cue furious comments from the 'friends of the 41' brigade...
Offline alibx11
  • Bike: 2012 V Strom 650 al2
« Reply #7561 on: May 12, 2017, 16:26:32 »
Just put a nice new DID Gold chain and Ognibene Silent sprockets... hope to get a few miles done on Sunday if the weathers good to see just how silent they are.
Also changed the handlebars to Renthall High Roads and put my 1" bar risers on them, they are narrower than standard so no issues at all with cable or hose length.
Offline 2112
« Reply #7562 on: May 12, 2017, 17:13:45 »
Today I fitted my Cosmo center stand to my Vee. It was a bit of a struggle (mostly due to having fingers like links of sausage) but it's on.
Offline 2112
« Reply #7563 on: May 13, 2017, 15:42:40 »
Another successful day in the garage - +25mm jack up links fitted, 25mm Cymarc peg lowering kit installed and the Heed engine bars are on. Off out for a 50th birthday party tonight  :obscene-drinkingchug:
Offline Geordie20
  • Bike: Yamaha FJR 1300
« Reply #7564 on: May 13, 2017, 20:31:32 »
Stripped out clutch basket and sent to Sharealike to see if we can stop it sounding agricultural. 28000 miles and it sounds like a diesel. Here's hoping
Offline Sasquatch
  • Bike: DL650GT K9
« Reply #7565 on: May 14, 2017, 13:56:48 »
Sprayed exhaust pipes black
changed oil and filter
fixed 5v charging point
« Reply #7566 on: May 14, 2017, 17:04:00 »
Wheeled the Africa Twin past it and went out for a ride.
« Reply #7567 on: May 14, 2017, 22:32:52 »
Discovered a fork seal leak... have tried the old photograph film trick to see if it resolves the issue otherwise it'll be a seal change all round  :fix:
Went for a short ride around some fantastic B-roads and killed a squilion flies - suppose I ought to clean the bike now   :dl_hyperhysteria:
Then whilst riding home I started to convince myself I don't *need* to replace the Glee, just before discovering the hazard lights don't work again (although they do if you indicate with the switch on). This is a reoccurring issue with the bike, namely as I don't use them they don't work, then I have to turn them on/off/on/off/on/off... then leave them 'on' then they start working again and are fine for a while. Have sprayed half a can of contact cleaner in the housing. Why oh why does Suzuki feel the need to ruin a fantastic bike by using the worst electrics I've ever come across on the motorbikes I've owned..?  :shrug:  :bawl:
I'll be test riding a Tiger 800 next weekend...
Offline Hugh Mungus
  • Bike: Fazer 1000
« Reply #7568 on: May 14, 2017, 23:38:54 »
I fitted one when I got my Vee last year. I have had a few grounding out issues when riding with a pillion (she only weighs 8 stones so weight is not an issue with her). I have the rear suspension on max but the stand still seems to sit quite low. The centre stand grounds when cornering at speed, I'm wondering if the rear shock is past its best (like most things have been on this bike) but if I jack it up I will struggle to reach the floor. I might take it off and see if I can do without.
Offline 2112
« Reply #7569 on: May 15, 2017, 09:50:45 »
It sounds like you could have a mushy rear shock to me. Most bikes rear shocks are on the way out by the time they get to 20,000 miles anyway, some hang on a bit longer. Depending on the mileage it could be well past renewal time ? Mines not very good (29k) but it will last until winter when I will either replace it or have it rebuilt. The front is also mushy and soft and will be getting rebuilt over the winter too.
Offline user650
« Reply #7570 on: May 15, 2017, 16:52:54 »
Gave it a bit of TLC ahead of the Devon Meet :thumb:
Changed brake fluid not technically due but brown ale colour in sight glass made me do it early  :shrug:
Refitted standard dog bones as much two up riding causing bike/road contact  :shrug:
Noticed play in shock area, traced to not tight top shocker mount, a few have had this so check yours, (Torque setting 50 Nm)  :fix:
Removed the wheels to get the new t130 evo's fitted on Thursday, hoping they last a bit longer. :thumb:
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Online Graham62
  • Bike: DL650 K6 Blue
« Reply #7571 on: May 15, 2017, 17:16:28 »
I had play at top shock bush two years ago, Torqued it up all still OK. :thumb:
Graham
Offline endintears
  • Bike: KTM 1190 Adventure
« Reply #7572 on: May 15, 2017, 18:30:56 »
"Retighten top shock bush"me
too.
T30 tyres :thumb:
Offline SuzukiSte
« Reply #7573 on: May 15, 2017, 19:55:30 »
Rode it in the pouring rain, and sailed home from work. lol
Offline Hugh Mungus
  • Bike: Fazer 1000
« Reply #7574 on: May 15, 2017, 20:49:09 »
I was thinking the same. About time I checked the sag, probably way over the limits...
« Reply #7575 on: May 15, 2017, 21:09:36 »
Saved myself a job of cleaning the squillions of bugs off the bike by going out in the rain  :thumb:  more time for riding now  :auto-dirtbike:
Offline hotbulb
  • Bike: DL650 L4
« Reply #7576 on: May 16, 2017, 13:34:31 »
I've just finished fitting a (birthday present  :clap:) Scottoiler to the Glee ...... perhaps the rain will stop (eventually) and I can go for a "test run"  :smirk:
Offline 2112
« Reply #7577 on: May 17, 2017, 17:51:25 »
Today I dropped the seat off in the capable hands of Jeff at Saddlecraft (www.saddlecraft.co.uk) to have it re-shaped and have a gel pad fitted. It'll be ready for me when I get back from my hollies  :thumb:
Offline Sasquatch
  • Bike: DL650GT K9
« Reply #7578 on: May 18, 2017, 18:42:18 »
Fitted Oxford x20 tank bag, using bodged up engineered mounting ring. Couldn't find confirmed working ring. Oxford useless support never sent me drawings of all rings, so I've bought closest match, OL282(type3 7 hole Honda). Didn't fit, so I made it fit:
ring on the bike:
how it's done:
bag on bike:
almost forgotten about aprillia style mirrors :)
Offline hotbulb
  • Bike: DL650 L4
« Reply #7579 on: May 18, 2017, 20:10:30 »
Got my "test run" for the new Scottoiler - Forest of Dean / Tintern. The Scottoiler's working fine........ and I enjoyed my few hours out on the bikes.
