Tank & airbox off, partly to check everything was assembled & routed correctly after the recalls (it was) & partly because I wanted to get in there & check all of the electrical connectors.
I decided not to sheath the connectors so dismantled them, thoroughly & lathered them in waxoil then relocated them higher behind the frame spar, I hadn't realised there was so much room in front of the airbox - why oh why didn't Suzuki make a row of brackets to support the connectors....?
Anyway, a final gloopy dollop of waxoil to seal them up & all good.
It's good to see my several squirtings of spray grease to the connectors when I first got the bike, kept all corrosion away.
It also gave an oportunity to check & blow out the air filter & run wire from my relay fusebox to power the heated grips & Sat Nav.
Tomorrow, refit sump guard, chain oiker & the shit kit removed before it went in.
