Author Topic: What have you done with your V-Strom today?  (Read 1397206 times)
Joe Rocket, NeilM and 10 Guests are viewing this topic.
« Reply #7340 on: December 17, 2016, 20:56:09 »
I could give it a go... I break everything else.
« Reply #7341 on: December 17, 2016, 22:25:00 »
That's an old misconception. I remember learning glass was a super cooled liquid years ago but it's an amorphous solid according to today's science. https://www.scientificamerican.com/article/fact-fiction-glass-liquid/
Anyway, remember to maintain your bikes or your brakes may break. Is the problem with homophones generation dependent? We were drilled on the differences when I was in school but it seems like that isn't happening any more.
« Reply #7342 on: December 17, 2016, 22:38:25 »
People no longer read. When they rite, vey put wot it souns like.  The "ITA" system of the late '60s to mid '70s encouraged primary pupils to write a word as it sounded and not worry about correct spellings, just to get them writing. Two contributory factors, I reckon.
Shame about the glass. Another myth, erm, shattered.
Offline mrp192
  • Bike: V-Strom 1050
« Reply #7343 on: December 20, 2016, 16:39:06 »
Needed to pick up some small bits from a town about 25 miles away so took advantage of the dry day to give my Glee a run out and avoid the seasonal traffic.
Got a bit carried away and ended up doing nearly 100 miles on some lovely Norfolk A and B roads that were completely dry. Good test of the new heated grips as well, 5' on temp gauge, winter gloves and grips on 50% made for a very comfortable trip.
Online UK_Vstrom650
« Reply #7344 on: December 20, 2016, 22:33:17 »
Adjusted the chain slack back to the recommended 30mm - took half a turn to do (new chain in July and 2nd adjustment, been meaning to do it for about a month). Forgot how much difference a properly adjusted chain makes to gear changes.
ProfG
« Reply #7345 on: December 24, 2016, 17:58:43 »
Yesterday after driving through the rain, I washed and cleaned the bike thoroughly. First snow foam, then a good rinse followed by a good vehicle shampoo wash, rinse and dry. Bike came out gleaming (except the seat).
Today was supposed to be dry so I had planned to deliver my Christmas cards (now it is cheaper to deliver them all over the city than to post them, even second class post). Well, what did it do? Effing rain  :dl_soapbox:
Came back in and gave it a good rinse but no shampoo then dried it. It is as good as new and garaged until tomorrow when I shall go for a good ride when the streets are empty :xmas-smile:
Offline Stonec0ld
  • I was Paul_Nicholson
  • Bike: DL650A L5
« Reply #7346 on: December 24, 2016, 18:00:37 »
Went to check my bike was still OK, and the number plate was smashed and on the floor... I'm hoping it was just the wind and no-one else trying to steal it. Everything else looked fine, cover still on, no damage, just the number plate cracked and fallen off
Offline Lincsman
« Reply #7347 on: December 24, 2016, 18:16:43 »
Fitted an R&G Radiator guard, which I got off e bay new for £35.00.
Simple enough.
DO YOU CARE ??
https://www.mag-uk.org/
Offline Captain
« Reply #7348 on: December 26, 2016, 15:30:56 »
Removed my forks on my 09 wee. Stripped them down cleaned and rebuilt refitted. 2016 Veek fitted scorpion carbon end can now it sounds like it should.
Offline endintears
  • Bike: KTM 1190 Adventure
« Reply #7349 on: December 26, 2016, 15:39:58 »
Rear pads
Was going to start annual maintenance later in the week but looks like there may be some riding weather :lala:
« Reply #7350 on: December 26, 2016, 16:03:28 »
The strom seems to have found its way into the conservatory again... The plan is to replace the rusty fasteners, repaint the water pump housing and have the engine bars and other bits  powder coated. First job is the annual oil and filter change...
Sent using carrier pigeon...
Offline Hondaman
  • Bike: 650 L3
« Reply #7351 on: December 28, 2016, 22:30:30 »
Started fitting my heated seat pad that santa dropped off for Xmas.
I drilled the foam & base to run the cable out and do away with the bulky 5 way connector (for 3 wires).
Hit a snag when my electric Staple gun won't drive the staples in. I'll drop it into an auto trimmers for re stapling.
Watch this space.....
Offline chrisdibber
  • Shit Happens
  • Bike: DL 1000 k9, bmw f650st,
« Reply #7352 on: December 29, 2016, 11:14:40 »
Fitted Takico 4 pot calipers, Scandinavian Braking Pads, HEL Braded hoses front, rear & Clutch, Replaced engine casing bolts with Stainless items, Fitted Gear Position Indicator, & Handlebar Brace.
Jobs to do before first Outing of 2017, Fork Brace & Skid plate :fix:
Online UK_Vstrom650
« Reply #7353 on: December 30, 2016, 20:19:21 »
Quick ride around the block. Noticed my speedo has had condensation on the inside of the glass which has dried  leaving a streak. May have to see if I can disassemble and clean  :dl_smiley_banghead:
Offline Coast
  • Bike: 22 Strom 650
« Reply #7354 on: December 30, 2016, 22:23:00 »
My speedo also suffers from the same problem...bottom right hand corner, especially in damp weather
Offline Petstep
« Reply #7355 on: January 02, 2017, 17:22:36 »
New Year's blast around North Devon and a bit of Somerset. Felt pretty elephantine with 5 layers under my bike gear, but managed to stay nice & toasty! Rediscovered a great chippie by the harbour in Ilfracombe
Offline superteso
  • Bike: K1300GT my2010, V-Strom 1000 my2014
« Reply #7356 on: January 02, 2017, 18:59:49 »
Buy a new seat.
Shad black & white.
si stava meglio quando si stava peggio
Offline Hondaman
  • Bike: 650 L3
« Reply #7357 on: January 02, 2017, 21:41:46 »
Wired in my 3 way relay fuse block, each fuse supplying 2 wires giving 6 outputs to feed my headed grips (currently fed from horn circuit), heated jacket liner (currently direct to battery) and my new heated seat insert plus a couple of low power stuff like Sat Nav, power to top box etc.
These little jobs seem to take me ages as I try not to end up with a rats nest but invariably do!
The common -ve point in their pic is for all circuits to earth to leaving only 1 -ve wire to the battery and hooefully keep things tidier or at least a bit less cluttered!
Offline Lincsman
« Reply #7358 on: January 02, 2017, 21:48:38 »
Well as someone who hasn't a clue about electrics, it looks nice and tidy to me.  :thumb:
DO YOU CARE ??
Offline Hondaman
  • Bike: 650 L3
« Reply #7359 on: January 02, 2017, 22:04:19 »
Thanks but give it time, I haven't finished yet!
