Author Topic: What have you done with your V-Strom today?  (Read 1397221 times)
Rusty Nuts, Joe Rocket, NeilM and 20 Guests are viewing this topic.
Offline Hondaman
  • Bike: 650 L3
« Reply #7280 on: November 22, 2016, 22:20:58 »
Fitted a heavier spring (that I had in my parts bin) to the glee rear shock.
Quick & easy enough to do, so no biggie if it doesn't work out.
Lets see if it cures the bottoming out I get on spirited run outs!!!
Offline Stonec0ld
  • I was Paul_Nicholson
  • Bike: DL650A L5
« Reply #7281 on: November 26, 2016, 17:59:35 »
Went for a ride over the Peaks to J&S Northwich, and it was absolutely freezing! Foggy and -1 on the dash gauge, I was dodging icy puddles, but it was a fun ride. My big toes and thumbs started to get numb after a couple of hours though. I was looking for some winter gloves in J&S as they have a 20% off sale at the moment, but they only seemed to have small or 5XL sizes. Who the hell wears 5XL??? Bought some inner gloves instead, seemed to work a treat. Also bought a iXS Tex-Zip 2 for £32, that's half price compared to Sportsbikeshop.
Got home and the bike is white with salt... Too cold to wash it tonight, so I covered it up and I'll wash it tomorrow after Motorcycle Live. Also ordered some ACF 50 from Opie Oils after everyone seems to rave about it, from what I read it looks like good stuff
Offline Freddyfruitbat
  • Bike: BMW R1200RS
« Reply #7282 on: November 26, 2016, 18:56:32 »
I did exactly the same last Saturday (wasn't so cold!); had just the same issue but they were perfectly happy to take my order at the discount price, and deliver the correct size post-free.  Received my toasty, perfectly fitting new gloves on Tuesday!  :thumb:
« Reply #7283 on: November 26, 2016, 19:14:27 »
Not me, mine are only 4XL  :)
Offline Stonec0ld
  • Bike: DL650A L5
« Reply #7284 on: November 26, 2016, 19:59:04 »
Bloody hell, I guess you save on Snow shovels come winter time...
Offline Dark-Strom
  • Bike: 2018 Ninja 650 & 2018 Ducati Scrambler 800
« Reply #7285 on: November 26, 2016, 20:57:32 »
Have not used the Strom for about 5 weeks due to weather / time, so uncovered (Tarp with bike cover underneath) and started it up. Ran it up temperature, followed by a shammy down and recoat with duck-oil on forks/ frame / engine / exhaust / bolts to keep corrosion at bay (gives a nice finish on the plastics too :)).
Offline mrp192
  • Bike: V-Strom 1050
« Reply #7286 on: November 26, 2016, 21:07:38 »
Took my Glee out on a back road jaunt in North Norfolk to try out my new heated grips.
Ended up taking the whole day and doing just shy of 200 miles they were so good and none of the usual pain in all my fingers after about 40 minutes of below 5 degrees.
Now covered in filth but dry so tucked away in garage until tomorrow for a good clean.
Offline JonJo
  • Bike: DL650 AL4
« Reply #7287 on: November 27, 2016, 19:28:23 »
BBC forecast was for dry weather and 9°C so called up a couple of mates at short notice to go out for a ride.
BBC lied - it was drizzly and bloody cold but we went out anyway. Had a buzz around the North Pennines on wet, salty roads and didn't see another road bike all day. Treated bike to snow foam clean and plenty of ACF50 when I got home.
Hear all, see all, say nowt
  • Bike: BMW R1200RS
« Reply #7288 on: November 27, 2016, 19:48:30 »
So this amazing ACF50 stuff, which I keep hearing about but have never used: presumably you have to re-apply it in between every wash?  If so doesn't it get a bit expensive?  Or is it, like, once per season or something?
Offline user650
« Reply #7289 on: November 27, 2016, 20:13:20 »
Have a read here  :thumb:
http://www.acf-50.co.uk/
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
ProfG
« Reply #7290 on: November 27, 2016, 20:18:05 »
This amazing ACF50 stuff that you keep on hearing about is expensive if you keep on applying it after every wash, so, the way to do it is wash your bike very well with a detergent, then rinse it completely and dry it out. You should then apply ACF50 with either a brush, but preferably from a spray bottle. Leave it to expand into every nook and cranny (cover the tyres and brakes before you apply it but remove your seat and apply it there also. Then rub it in with a good microfibre cloth.
Next time you need to wash your bike, don't use any detergent, just water and wipe it down with a cloth while rinsing the bike and let it dry. If you use a detergent it will wash away the ACF50.
You can keep the microfibre cloth which now has ACF50 on it and when the bike is dry just rub it on the exposed pars.
Alternatively you can have it done professionally by All Year Biker as they do a much better and professional job than anyone can do themselves since they have all the equipment and they will hand over your bike to you in showroom condition (they will do it on your own premises if you want) and they will give you a one year guarantee. This is what I do, I let them do my bike once a year and the money is in my opinion money well spent.
« Reply #7291 on: November 27, 2016, 22:12:12 »
Fitted a Keis Bluetooth controller for my heated jacket. Got fed up with struggling to adjust the temp when on the move. Am hoping it works well, though Keis really should try harder with their designs as the controller is massive, they don't supply enough rubber to clamp it to the handlebars, and best of all even though it is water-resistant the instructions say 'don't get the controller wet'...???
Here's a picture (may have to think of finding an alternative mounting location though as it is hideous!)
« Reply #7292 on: November 29, 2016, 22:12:43 »
Sun was shining so took the good lady up to The Monyash Café for a late (all day) breakfast. Came back on gritted/salt roads so gave the bike a wash when we got back. Got a bit dark to do the job properly so dried it off with my 'pet drier' and put it in the garage until Thursday when I'll finish the job and ACF 50 it.
Had a bit of a discussion with a man walking his dog who slipped on the frozen run off from my drive onto the pavement. Borrowed the salt (all of it) out of the kitchen and used it to de-ice the area ................. should have left it and taken my chances with the dog walkers 'cause the discussion with the good lady when she found there was no salt for her tomato sandwhich was a little more terse!!!!  :violence-smack:
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #7293 on: November 30, 2016, 14:04:51 »
Bluetooth controller? I just cut the wires on the normal controller, lengthened and made a bracket to mount them on the handlebars.
« Reply #7294 on: December 01, 2016, 13:16:24 »
Good idea, but I'm struggling to run any additional wires under the tank, and want the original controller for running the heated insoles I have, otherwise they burn your feet.
« Reply #7295 on: December 01, 2016, 14:26:17 »
Welcomed the new Wee into the family.
AK9 first registered in 2010 on a 60 plate. 4700 miles and hardly a mark on it.
OK so what's on the to do list?
New tyres (currently the 'orrid OE B'stones)
Fit crash bars
Water and oil rad guards (have boewulfs in shed)
install Aux supply (bigpie kit on the shelf ex Glee / Tracer)
Install PD mini chain oiler (On the shelf ex Tracer)
Heated grips ( to get)
Bigger adjustable screen ( needs research and cash)
Fit mirrors and extenders (on the shelf ex Glee)
Fit Squanto Tracker (to get).
Fit fork gaitors ( Fleabay'd arriving soon)
Any other suggestions?
« Reply #7296 on: December 01, 2016, 14:36:54 »
Don't forget the pie tray indicator reflectors...nom!
Sent using carrier pigeon...
« Reply #7297 on: December 01, 2016, 14:43:11 »
Oh! dear how did I forget those  :shy:
« Reply #7298 on: December 01, 2016, 14:47:40 »
'Tis the season for mince pies too!
« Reply #7299 on: December 01, 2016, 15:41:04 »
Sump Guard & V-Strom.co.uk Gel decals.
