Author Topic: What have you done with your V-Strom today?  (Read 1398533 times)
0 Members and 7 Guests are viewing this topic.
Offline Hugo Magnus
« Reply #6780 on: May 10, 2016, 10:03:29 »
Just sailed through my first MoT at 19,500 miles. I still can't believe I've'e had it 3 years already! I wouldn't change it for anything else, (though I may add to my stable :grin:).
ProfG
« Reply #6781 on: May 10, 2016, 10:10:18 »
Not today but Sunday. Tightened the chain. Changed the oil and filter although the old oil seemed decent enough since it had only done 6000 miles.
Today put Adventure A40s so a fair bit of slow careful riding until the shit is cleaned from it.
Offline joderest
  • Bike: DL650 K6
« Reply #6782 on: May 10, 2016, 15:15:43 »
Over weekend.
Stripped rear end down, cleaned and repainted all rusty bits, cleaned and gave caliper a coat of silk black, new rear brake line, refurbished master cylinder, new pads, painted spring on shock as rusty, repainted suspension links, re logo'ed side panels and gave coat of clear over the top to stop the bloody things coming off, put it all back together, now front end stripped, brakes having same treatment, cleaned off top of engine ready to do a service.
Hope !!!!, to have it all back together next week end, looking almost new again !!!
Offline S2Rgar
  • Bike: DL1000 L9 Black - DL650 AL5 Red (SOLD) - DL650 AL3 Grey (SOLD) Suzuki GSX-S1000
« Reply #6783 on: May 10, 2016, 22:24:47 »
A 400+ mile run to Inverness and back starting at daft o'clock in the morning  :dl_ninite:
Offline wurzel
« Reply #6784 on: May 10, 2016, 23:00:21 »
That's a fair old hop,bet your knackered but happy. :clap:
Offline S2Rgar
« Reply #6785 on: May 10, 2016, 23:05:24 »
My new Sargent seat made it possible... the standard seat usually had me crippled in around half that.  Was a great day out though with temps from 6 - 28 deg.
Offline mrp192
  • Bike: V-Strom 1050
« Reply #6786 on: May 12, 2016, 11:42:55 »
Fitted my bigpie aux fusebox but ran out of time to carry on getting the body work off to run the cables through for new heated grips, satnav and BikeVis led's .
Offline joderest
  • Bike: DL650 K6
« Reply #6787 on: May 12, 2016, 13:19:54 »
well, not a good day, ordered a 2nd hand chain guard off e bay, has got v strom cut into it, however, it does not fit, hole spacings miles out, must be for a 1000 or newer bike, oh well, modification time, worked out how to do it using parts off the plastic guard.
Ordered some new flush fit front indicators, as my sticky out ones wobble, arrived today, sent incorrect ones. Oh well, waiting again for correct ones to turn up.
Offline Flanners
« Reply #6788 on: May 12, 2016, 15:13:27 »
Spent 3 hours I should have been riding in the sun stripping down the starter switch and reassembling it twice only to find the bike wouldn't start due to an aftermarket clutch lever on the 1 setting.....FFS :fix: The bike is mint and gleaming as only used in Spring/Summer so wondered why the starter button would fail/corrode. Fiddly business getting all the bits with the spring in place back in...very agricultural in design too.
Offline Hondaman
  • Bike: 650 L3
« Reply #6789 on: May 12, 2016, 23:39:57 »
It was inevitably going to happen - I knocked out the baffles of my already decatted  stock exhaust.
A courtesy run out to scrub the A40s & check the quality of exhaust work :)
Offline alibx11
  • Bike: 2012 V Strom 650 al2
« Reply #6790 on: May 13, 2016, 19:10:23 »
Changed my oil and filter and ordered a Scorpion Titanium exhaust and removed the standard system ready for fitting, should be here next Tuesday...   :happydance:
Offline mrp192
« Reply #6791 on: May 13, 2016, 21:09:51 »
Removed the bodywork and raised the tank to allow better access to run my bigpie headlight relay loom, satnav and heated grips power leads through to the front of the bike.
Took my time, most of the day, to try and not make any mistakes or break the plastics and got it done in the end. Also ran my BikeVis led's wiring from the accessory bars back to my aux fuse box but ran out of time to connect them as had trouble with crimping the terminals.
Would just like to say  :ty: to bigpie for not only making the bits for me but also answering several questions which gave me the confidence to have a go.
Offline AndyJOxford
« Reply #6792 on: May 13, 2016, 21:16:21 »
Fitted delkevic cans to my 2004 vee, hoping for a good weekend to frighten the locals around west Oxon/Cotswolds
Offline StromGeeza
  • Global Moderator
  • Bike: just scoots now
« Reply #6793 on: May 14, 2016, 20:58:38 »
After reading about cleaning the front sprocket area on this illustrious forum, I thought I'd check mine out. :fix:
There was a certain amount of crud in there, but not as much as some have found, although I'm only on 8,000 miles. Worst was the spacer that fits behind the topmost slave cylinder bolt. The bike's a few grams lighter now, anyhoo...
ProfG
« Reply #6794 on: May 14, 2016, 22:05:05 »
The fellow on the youtube video makes it look very easy although I suppose he's been doing it day in day out. Try fitting the damn thing with a hugger.
Anyway, now to test ride it tomorrow for around 160 miles and see how it behaves.
Offline joderest
  • Bike: DL650 K6
« Reply #6795 on: May 15, 2016, 17:14:55 »
Hi All
If I have done this correctly you should find some pictures of the work I have done for last two weeks, getting rid of the winter rust and crud, I have also fitted new stainless brake lines front and rear, and also tarted up my rad cover I made last year. New decals, which are clear coated over, and lots of painting here and there.
Its all ready to go out and get rusty again !!!!
« Reply #6796 on: May 15, 2016, 17:16:02 »
I finally got out for a ride (just my third of the year as work is really getting in the way) and decided on the usual "just disappear down some narrow lanes and keep going" option. I take a Sat Nav with me just to give me the option of seeing where I have been when I get home.
Today was just 58 miles in 2 hours, so a really low average speed that reflects some of the roads I was on.
At one point I found myself going along some skinny lane for several miles without seeing anyone, when suddenly my Sat Nav (very accurately) told me the following ....
Offline wurzel
« Reply #6797 on: May 15, 2016, 17:17:20 »
That looks really smart, good work I say :)
Rode mine to Scotland today,last leg in the morning.
Offline Jameswigan
  • Bike: VStrom 650 GT 09
« Reply #6798 on: May 16, 2016, 19:37:02 »
Taken delivery of 2 new metzeler roadtec 01 tyres for my 2009 wee wheels taken off ready for fitting this week.should stick like glue  :lala:
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #6799 on: May 16, 2016, 20:58:53 »
Got my battleaxe A40 adventures fitted and my wallet emptied.
Sent from my Nexus 4 using Tapatalk
