Author Topic: What have you done with your V-Strom today?  (Read 1314878 times)
Offline purplebikeunicorn
  • Bike: DL650A L7
« Reply #11280 on: May 21, 2023, 17:20:50 »
Nice long trip today, had a little adventure round before heading home after a short camping trip in Wales. After not doing a lot of mileage last year, I think I've beaten the entire years mileage so far and we're only in May. Definitely becoming much much more confident with the bike and what it can do, even loaded up with luggage (albeit not that heavy, but would have definitely added some wind resistance).
It pished it down on Friday, and getting back today, noticed there was some grimey crud around my fork dust seals and up the forks. Wiped it off, doesn't smell oily at all... Popped the dust seals off, and above the oil seal is full of water and gunky dirty mess, wiped off and water/gunk mopped up, seals refitted, and I'm now only left with a very faint ring where the dust seal gets to. I think this is actually forming in the XCP, maybe with the remnants of water inside the dust seal, rather than a fork oil leak, but will keep an eye on it.
Unfortunately with the wet riding my squeaky brakes have returned, and my sticky throttle. The latter I have tightened the pull cable slightly which fixed that (don't understand why that fixed it, but Hello ho). The brakes I will have a look at/clean (again!) next week when I have some more time to myself... might even treat myself to some new, known name brake pads
Offline nigel s
  • Bike: DL650A M2
« Reply #11281 on: May 21, 2023, 17:23:26 »
I can recomend ebc hh ,more initial bite than standard ,good in wet.
  • Bike: DL650A L7
« Reply #11282 on: May 21, 2023, 17:24:11 »
I was looking at those, did hear that they're not great initially until they warm up (and are harsh on discs), but I'll take anything that stops the bloody squealing
Offline graingerblaze
  • Bike: DL1050
« Reply #11283 on: May 21, 2023, 17:29:55 »
I have the EBC HH pads and after 2k still no squeaking  :thumb:
DL1050 Grey (2020) V-Strom
Offline nigel s
  • Bike: DL650A M2
« Reply #11284 on: May 21, 2023, 17:34:32 »
Probably won't help with squeeling,that's pistons or sliders or pad edges sticking in calipers.I had ebc hh on my fazer 1000 for 70,000 miles on original discs,I imagine strom would be OK too, no warming up needed.See my post in sv1000 caliper upgrade for bedding in.
I'm assuming you have kept the anti squeel pad backs?
Offline nigel s
  • Bike: DL650A M2
« Reply #11285 on: May 21, 2023, 17:44:40 »
Squeel ......... squeal?
ho hum
  • Bike: DL650A L7
« Reply #11286 on: May 21, 2023, 17:49:58 »
I had this squeal before, took the pads out and gave the disc a good clean (and brushed the surface of the pads with a brass brush following Haynes). That seemed to fix it for 100+ miles, only really started squealing again after the wet ride. Might also be a coincidence. The discs look OK with no grooves or anything you can feel the edge of. Discs are 4.7mm each side.
Have ordered some new EBC HH pads, and will keep my eye out for the shims, I know the springs were there, but I can't recall from memory if I saw anything on the back of the pads.
Offline nigel s
  • Bike: DL650A M2
« Reply #11287 on: May 21, 2023, 17:53:16 »
On the back of the original pads is a copper shim clipped to it ,it's easily missed and discarded . This is the anti squeal shim and should be taken off and put on new pads.
Also check out Dr v strom on you tube he has a vid on this it's all good advice.
Offline midiman1962
  • Bike: Yamaha FJR 1300,Suzuki DL650
« Reply #11288 on: May 21, 2023, 18:41:11 »
I attempted to take off the side panels - this wasn’t a success! Watched a couple of videos- do I need to take the front under headlight plastic off before the side panels ?
  • Bike: DL1050
« Reply #11289 on: May 21, 2023, 19:04:06 »
I can’t speak for later generations, but for the first generation 650 you do need to remove the black plastic inner fairing under the headlight, it has clips that lock to the side panels  :)
« Reply #11290 on: May 21, 2023, 19:06:26 »
What year bike midiman?
Offline midiman1962
« Reply #11291 on: May 21, 2023, 20:03:19 »
It’s a 2010 I think
Offline nigel s
  • Bike: DL650A M2
« Reply #11292 on: May 22, 2023, 17:55:59 »
Ordered the madstad brackets for the 650 today ,should turn up tomorrow.£175   ouch!
« Reply #11293 on: May 22, 2023, 22:12:26 »
Loaded it up & took it on the first (proper) trip of the year to sunny Devon. :sunny:
Offline Upt North
  • Bike: DL650 L7
« Reply #11294 on: May 22, 2023, 22:40:54 »
Walked in the garage and caboom! :fix:
Offline nigel s
  • Bike: DL650A M2
« Reply #11295 on: May 23, 2023, 04:33:47 »
Bloody thieving b@stards will have anything these days!
ho hum
Is that an air freshener plugged into the left hand socket above your handle bars?
Offline sjrainsford
« Reply #11296 on: May 23, 2023, 07:58:40 »
Changed the screen  :fix:
Again!  :groan:
Offline Upt North
  • Bike: DL650 L7
« Reply #11297 on: May 23, 2023, 08:04:31 »
Sadly not, although an essence of VSTROM room purification device must be a winner. It's a rodent deterrent device, one of two. We're pretty remote and it's very common to see mice, voles and rats etc in the vicinity.
Ask me if they work? Go on!
don't know......but I've never had rodent damage to vehicles in the garage. What have I said.....
As an aside the air filter (not the reason for caboom) was shitty. Gave it a blow out with an airline, couldn't really believe how much crap was in there, probably because of the front intake location?
Or is it the mice  :icon_batterup:
Offline nigel s
  • Bike: DL650A M2
« Reply #11298 on: May 23, 2023, 10:10:09 »
As an ex farmer I can attest to the amount of  damage  mice and  rats can do ,bloody  things.
Offline pichulec
  • Bike: KTM 1290 SAS
« Reply #11299 on: May 23, 2023, 20:49:42 »
Removed rear brake disc in a wait for new one. I had an unfortunate event of ride off with disc lock attached, simply forgot about it :( Disc bent. Bought Tourmax replacement, hopefully it is not some cheap Chinese. Even if it is, will have to suffice for a while..... Can't afford any better now.
