And all of that for cost of £17 + paints. It is from SV1000 but it is the same engine so it will fit.
New cover £105 + back order, so I would not be able to go to Spain.
Saturday, new oil + coolant + water pump cover (with the new oring), assembly and test.
I also changed the clutch plates and metal plates too (hopefully I have assembled correctly, used schematics from Fowlers).
