Author Topic: CLUTCH IDLE RATTLE  (Read 1086 times)
Offline ricky
CLUTCH IDLE RATTLE
« on: November 25, 2011, 19:05:41 »
hi
on my 650 done about 700 odd miles now had first service done
when cold I can hear a loud rattle which goes when I pull the clutch in.
onces warmed up its still there but a little hard to hear but you can still hear it and again goes once clutch pulled in.
what could be causing this? or is it the norm for this engine?
Offline medic5
Re: CLUTCH IDLE RATTLE
« Reply #1 on: November 25, 2011, 19:15:49 »
Not normal but do have the clutch rechecked as I know one Suzuki workshop oil monkey can often not be as good as another oil monkey as I know to my cost when I tried a different workshop. :fix:  :groan:
Offline 2112
« Reply #2 on: November 25, 2011, 19:19:32 »
It sounds like the classic thrust bearing which can get quite noisy quite quick. Have it checked by a Suzuki monkey but it'll probably be making the same noise in 80,000 miles time.
Offline ricky
« Reply #3 on: November 25, 2011, 19:32:38 »
Quote from: "2112"
yep definitely sounds like a thrust bearing to me, I'm used to the noise from working on cars and having to change the clutch bearings.
motorcycles I have not had the joys of doing clutchs yet.
I take it they have the same sort of bearing then?
Offline 2112
« Reply #4 on: November 25, 2011, 23:07:02 »
Similar, but smaller, more loads and more prone to a bit of 'elbow room'. " Don't wory sir, they all do that", as they say.
« Reply #5 on: November 26, 2011, 20:07:19 »
If it's only done 700 miles it's still under warranty, take it to a Suzuki dealer (there are less and less of them around nowadays...) and have it fixed. It's probably nothing serious, but if it does develop then they can't say it's your fault for not telling them this.
