Oil Filter Wrench
Topic: Oil Filter Wrench (Read 2086 times)
Dan The Man
Oil Filter Wrench
October 16, 2011, 10:06:46 »
Morning all,
Does anyone know if the Filter Wrench attatchment is the same throughout the range?
Ill be doing most of my servicing at home and changing the oil is childsplay but never had these kinds of filters before, I figure I can either Brute Strength it or attack it with several various sized rocks and assortment of hammers but I figure getting the right adaptor and putting a Torque Wrench on my Christmas list should be a good idea
... Bout time I got 'proper' tools
Be Safe,,,,,,,,,,,,,and if you can't be safe..........BE LETHAL.
Locky
Bike: Triumph Tiger 800xc & Yamaha TTR250
Re: Oil Filter Wrench
October 16, 2011, 10:56:04 »
I use this tool to remove mine
http://www.ebay.co.uk/itm/1-2-DRIVE-OIL ... 19c69fa93d
When fitting the new filter I just tighten by hand . I've'e always done it like this and never had a prob..
I've also got one of these but use it mainly on the car/van
http://www.ebay.co.uk/itm/12-OIL-FILTER ... 519b5ac52e
Should also work on bikes..
Dan The Man
October 16, 2011, 11:06:12 »
I was thinking of the Pilars approach as well but after watching several scraped knuckles in accidental *clunk* its loose fashion thought I might try the cap approach... needless to say they are going in my eBay watch list as we speak
Juvecu
Eat, Sleep, Ride, Repeat
Bike: '11 Versys 650 & '05 TT-R250
October 16, 2011, 13:47:16 »
I have one of
these
. I use it to loosen the filter only, I hand tighten the new filter that goes on.
Members Map
Juv's Strom "Restoration" (sold to Mad Phil)
Juv & Locky's Morocco Trip Report
Juv's Blog
WeeStromer
Bike: DL650 AL2 GLEE, CG125 ES5
October 16, 2011, 14:11:09 »
I have one like this. It only cost about 5 Euro from the supermarket.
http://www.ebay.co.uk/itm/Elora-Oil-Fuel-Filter-Removal-Tool-Pipe-Strap-Wrench-/140619551752?pt=UK_Hand_Tools_Equipment&hash=item20bd941408
frez
Reply #5 on:
October 16, 2011, 21:10:29 »
I'm pretty sure that all Suzukis use exactly the same filter. I picked up a cheap one on ebay some time ago. If you don't have one and can't remove with pliers a trick is to hammer a long screwdriver through the filter and use that to help turn it.
Gassoon
Quotes Museum Curator & Moderator
Bike: DL650X L7
Reply #6 on:
October 16, 2011, 21:25:36 »
I used to have a decent one but loaned it out and never saw it again
But my old man has a device for getting into his jars of pickles (he's addicted) and so on...and it works!
Similar to this one...
http://www.ebay.co.uk/itm/MULTI-PURPOSE-JAR-BOTTLE-OPENER-STRAP-WRENCH-OIL-FILTER-/110752977837?pt=UK_Kitchen_Accessories&hash=item19c96453ad
Blood* cheap, too
Coval
Reply #7 on:
October 17, 2011, 11:55:14 »
Like Juvecu, I hand tighten my filters, using considerable force to ensure they stay in place until the next oil change. A piece of sandpaper in the palm of your hand provides sufficient grip, as a result, never had an issue with unscrewing it.
Piaggio X9 250 > Kawa GPZ900R > Yam GTS1000 > Yam TDM900 > Yam FJR1300 > K7 Wee & '98 VFR800Fi
Dan The Man
Reply #8 on:
October 17, 2011, 16:08:24 »
Groovy I shall invest in a filter and some oil ready for a 100 miles initial break in swap out to clear most of the shards out then let the 650 mile service be the big one for the remaining few then continue to DIY for the rest of the Stroms long life
Ptarmigan
Bike: CRF1000 Africa Twin
Reply #9 on:
October 17, 2011, 16:35:05 »
Quote from: "Dan The Man"
Good offer on Torque Wrenches at Aldi right now @ £14.99. I got one last Monday after someone had posted it on here over the weekend, Save the expensive pressies for Christmas
Which part of Sheffield are you in?
Dan The Man
Reply #10 on:
October 17, 2011, 16:38:43 »
The nomans land of Dinnington (hardly really Sheffield, but commuting there everyday for work on the A57 sure evens that out)
Juvecu
Reply #11 on:
October 17, 2011, 17:04:27 »
Just a note on the hand tightening: don't over tighten it. Put a little oil on the rubber o-ring in the filter, spin it on until it seats, then 1.5-2 turns max. If you over tighten it you risk distorting the seal and causing a leak. The filter is in the perfect place to leak that oil smack in the middle of your rear tyre.
Members Map
Juv's Blog
Oil Filter Wrench
