Petrol in the air box....
Topic: Petrol in the air box.... (Read 1087 times)
Strommer
October 14, 2011, 20:11:05 »
Why?
A disgrace to biking...
2112
Bike: Honda 750 Transalp, Victory Crossroads 1731
Re: Petrol in the air box....
October 14, 2011, 22:08:29 »
I suspect there is a breather for emmision regulation purposes which has clearly guffed some fuel out. This may be to protect the cat' as unburnt fuel kills cat' converters, just guessing mind. It certainly shouldn't be a lot of fuel ?
Juvecu
Eat, Sleep, Ride, Repeat
Bike: '11 Versys 650 & '05 TT-R250
October 15, 2011, 00:25:55 »
How much fuel is it?
Members Map
Juv's Strom "Restoration" (sold to Mad Phil)
Juv & Locky's Morocco Trip Report
Juv's Blog
Strommer
October 15, 2011, 07:44:47 »
just drips
Juvecu
October 15, 2011, 12:34:47 »
Are you sure it's fuel and not water? On mine the spunge thingy over the oil breather pipe's hole collects some water. For fuel to get in it has to get blown up from the throttle bodies (the injectors are in the throttle bodies.) Since the bike is sucking air all the time it is very unlikely for fuel to go against the air 'current'. Unless you're get a lot of fuel in your oil and that gets into the airbox via the oil breather pipe? I'm just thinking out loud, feel free to ignore me
A lot of the problems you're having are things that are difficult to troubleshoot without looking at the bike for oneself.
Members Map
Juv's Blog
SimonW
Bike: DL1050XT
Reply #5 on:
October 15, 2011, 17:42:22 »
Quote from: "Juvecu"
It's been a while since I did anything mechanical, but it struck me that one way to tell would be to drop a lighted match in. If the match fizzles out it's definitely water, but if it explodes in a massive fireball, taking out everything in a 50 metre radius it's definitely fuel. (Remember to put on some protective eye wear first.)
Juvecu
Reply #6 on:
October 15, 2011, 19:06:22 »
Hahahahaha! I imagined what that would look like and it was cartoon like funny
A safer way would be to soak a little bit into a tip of a rag and then try to light it in an open space (away from anything else flammable!) If it catches fire immediately it is fuel, if it catches fire after some persuasion it's probably oil, else it's water.
Members Map
Juv's Blog
