Gear lever main bolt working loose.
Topic: Gear lever main bolt working loose. (Read 688 times)
Strommer
October 12, 2011, 18:19:48 »
The main bolt (furthest back) that pretty much holds the lever on keeps working loose.
I've hand-tightened it a couple of times - is there someway to tool-tighten this - can't see any nut head or suchlike? Could I loctite it....? Top right bit, number 33.
A disgrace to biking...
Juvecu
Eat, Sleep, Ride, Repeat
Bike: '11 Versys 650 & '05 TT-R250
Re: Gear lever main bolt working loose.
October 12, 2011, 18:34:49 »
Not sure I get what you mean, pic?
Members Map
Juv's Strom "Restoration" (sold to Mad Phil)
Juv & Locky's Morocco Trip Report
Juv's Blog
Strommer
October 12, 2011, 19:08:33 »
Oops - now added to original post - top right bit, number 33.
Juvecu
October 13, 2011, 13:51:54 »
Ah, yes, normal Locktite should do the trick. Also, put some grease around the post so that the movement of the lever on the 'bolt' is not causing much friction.
Members Map
Juv's Blog
Strommer
October 13, 2011, 19:10:52 »
Willdo...will this never end...
Thanks.
