Could anyone comment on a service cost from a garage, uk, for a DL1000. Mate has one and has been getting some quotes together and they are high, just wonder if anyone that gets servicing done at a garage could add some comment?
Bike is low miles but has sat for a couple of years and has some corrosion and an oil leak from the sprocket shaft.
He is after a full inspection and check of all important bits, throttle, hoses, cables, switches. Adjustment of anything needed. Oil and filter change. Coolant flush and change. Chain, sprockets and swing-arm cleaned of a heavy layer of crud and old grease. Calipers stripped and cleaned. Whole bike given a deep clean and polish.
He is getting quoted about £1200 for all that. Does that sound OK? Quotes are from small service centres rather than a dealership.
