Author Topic: stanchtions  (Read 479 times)
Offline bigsimmo
  • Bike: DL1000 K8 in blue / glee in red
stanchtions
« on: July 13, 2024, 22:00:30 »
hi blokes,
          fork seals killed buy rust spots, hidding out of sight, or is it me not looking.
 has anyone tried the stanchtions from china? or better still anyone know best place to get them rechromed.
cheers blokes
steve
Re: stanchtions
« Reply #1 on: July 13, 2024, 22:28:24 »
Look up JMP fork stanchions..
I've fitted these to quite a few bikes and the quality is very good for the money.
Offline nigel s
  • Bike: DL650A M2
Re: stanchtions
« Reply #2 on: July 14, 2024, 04:46:56 »
Superglue and 1200g/2000g wet/dry is worth a go if they are just small spots of rust.Clean with acetone after removing any loose stuff carefully with a stanley blade point.Fill with Superglue (Loctite or Gorilla not the cheap stuff and not the gel, may need to build it up in goes.) leave at least overnight somewhere warm.Then 1200g (3m is best) across the fork not up and down, finish with the 2000g.
Offline SD12463
  • Bike: DL650A L8
Re: stanchtions
« Reply #3 on: July 14, 2024, 07:57:45 »
I've heard good things about this place....
https://www.brooksuspension.co.uk/
No experience of their services so don't really know anything about them.
Maybe worth researching or anyone else on the forum know about them?
Offline bigsimmo
Re: stanchtions
« Reply #4 on: July 14, 2024, 10:14:03 »
thanks blokes, not to sure about the glue, will it work? will it last?
steve
Offline MilozFolly
  • Bike: DL650 L3
Re: stanchtions
« Reply #5 on: July 14, 2024, 11:27:41 »
Depends how bad they are from what I've read.  I recently replaced my fork seals and took the opportunity to address the pitting (minor imo) whilst there.  It's mildly terrifying to take sandpaper to your pride and joy but I was very impressed by how much better they felt afterwards.  Maybe try that as a first step?
Offline nigel s
  • Bike: DL650A M2
Re: stanchtions
« Reply #6 on: July 14, 2024, 15:02:00 »
I have done the superglue thing on my old get to work Honda cb200, and it did work for the time I kept it (18 months and an MOT). It depends how bad they are. It is worth a try for what it costs, in my case Nowt...bar the new seals.But I did change the leaking seals myself. If you have to pay someone to do it for you, then the chance of it not working is more costly. :shrug:
Maybe give it a go and see what happens, then make a decision about the seal replacement.
Re: stanchtions
« Reply #7 on: July 14, 2024, 15:03:00 »
I've had a couple of mates had the stanchions rechromed by Brooks Suspension in the past & have been very happy with them.
I've had dealings buying from them & can say they seem to be a good company. Quick to reply to e-mails with answers to questions & I've had & great help on the phone too.
https://www.brooksuspension.co.uk/workshop/motorcycle-fork-rechroming-service-for-stanchions-both-legs
Offline Sculptor55
  • Bike: DL650XT AM3
Re: stanchtions
« Reply #8 on: July 14, 2024, 16:46:35 »
Not sure where you’re based, but I’ve used AM Philpot in Luton and was happy with the result.
https://www.pittedforks.co.uk/index.php
Offline bigsimmo
Re: stanchtions
« Reply #9 on: July 15, 2024, 20:03:03 »
thanks blokes, going to have them rechromed, going to get Brook suspension to do it I think. will do the rebuilld my self and fit new seals and bush.
got to do rear wheel bearings too, never ends does it. looks like a 2mth turn round on all work to be done, its OK I don't ride it much now.
cheers blokes
               steve
Online 2112
Re: stanchtions
« Reply #10 on: July 17, 2024, 05:32:02 »
I've used Philpotts (pitted forks) twice in the past (Kawasaki Z1r and a Suzuki GSX750) and they have been superb. Great service, good finish (slightly duller and less shiny than standard) and a perfect size - so no seal or bushing issues. I have used Brookes for suspension work and they were a little bit slow in the turnaround. Great quality work mind.
