Author Topic: Valve clearance  (Read 647 times)
Offline tony d
  • Bike: DL1000 L5
Valve clearance
« on: May 27, 2024, 13:10:10 »
Hi looking for the specs for valve clearance on my vst1000 2015 thanks
Re: Valve clearance
« Reply #1 on: May 27, 2024, 18:31:34 »
0.10-0.20mm inlet
0.20-0.30mm exhaust
Re: Valve clearance
« Reply #2 on: May 28, 2024, 07:09:58 »
A service manual may be of help to you at this stage, when starting with the valve inspection.
Have a look under https://www.v-strom.co.uk/downloads.htm for the link: "Suzuki V-Strom DL1000A L4 on Workshop Manual". This manual covers the L4 -L6 Veek models.
Offline Valzdl650
  • DL650 Paderborn germany
  • Bike: DL650 K5
Re: Valve clearance
« Reply #3 on: May 29, 2024, 18:34:21 »
I done valve clearances on 03.12.2023 72270km
Rear cylinder - right intake was 0.13 (0.10-0.20)
Front cylinder-left intake 0.13 both ex was 0.23(0.20-0.30) I’m now at 81000km and 6 month later , would you blokes recommend checking? I don’t really want to strip all down if not needed but I don’t no the time scales between checking …. Thanks ( all the rest where bang in the middle of tolerance) thanks
Offline Rixington43
  • Bike: DL1000GT K7
Re: Valve clearance
« Reply #4 on: May 29, 2024, 18:45:31 »
Valves are 15k miles between checks I believe, some manuals say 14.5k since they're in km and converted to miles but most go 15k miles.
Offline Valzdl650
  • Bike: DL650 K5
Re: Valve clearance
« Reply #5 on: May 29, 2024, 21:33:55 »
OK perfect then 4 ish thousand then I’ll check then cheers buddy
