Author Topic: Help.. I have problem😩  (Read 593 times)
Offline REM
« on: October 21, 2023, 18:57:31 »
My low beams are not working but the high beams are. What do I need to do to fix them? I checked the fuse and it is OK….my baby it’s 1000 2017 I don’t have switch on and off . Please help.
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
Re: Help.. I have problem😩
« Reply #1 on: October 21, 2023, 19:14:28 »
There was another thread recently similar to yours.
https://www.v-strom.co.uk/smf/index.php?topic=42756.0
Hope this helps until someone else comes along with a more specific answer, maybe. :thumb:
Offline REM
« Reply #2 on: October 22, 2023, 08:10:01 »
Thank you,yes I know 650 has a problem with the lights because I got the same situation model from 2012 and is connector. The left side is a burning but my it’s 1000 from 2017, I think everything is different.
Offline Upt North
  • Bike: DL650 L7
« Reply #3 on: October 22, 2023, 10:15:41 »
Firstly try a known good bulb, you never know.
Then check the relay.
Then if that fails the wiring.
Does the starter button cut dipped beams only on start up? If so check for sticking starter button.
I've got nothing else.
Upt.
« Reply #4 on: October 23, 2023, 07:08:35 »
Anyone perhaps have a digital copy of the wiring diagram for this model?
Offline phockit
  • Bike: DL1000A L9
« Reply #5 on: October 23, 2023, 11:32:59 »
Suspect the bulb has blown. Mine did this a while back (2019 DL1000), all good when I put it away, no light when I took it out next time.
Offline REM
« Reply #6 on: October 23, 2023, 17:55:24 »
After consulting NASA engineers and the great scholars from Oxford, after considering for and against, the source of the problem occurred in Suzuki, namely, no lights were identified. With a safe driving in mind, we managed to locate the cause of no light.After efficient and accurate inspection, we replaced the H7 light bulb for a new one.
