No start
Topic: No start (Read 359 times)
insayner
Bike: DL1050XT
No start
August 28, 2023, 10:22:14 »
Hi thanks for add my 1050xt will not start lost trip meter and mileage .mode button does not work if pull clutch in it will turn over have checked fuse,s all OK I do have a hill start fault.just hope the ecu has not gone down any idears.
Gert
Re: No start
August 29, 2023, 07:32:04 »
First off,
Before you press the starter button, do you hear the fuel pump prime when you turn the ignition on? If the gauges finishes the start up process, what is the battery voltage reading? Confirm that there is no CHEC message displayed on the gauges.
No start
