DL1000AL4 switched live feed.
Topic: DL1000AL4 switched live feed. (Read 1778 times)
KLV-Rider
February 23, 2020, 20:59:37 »
Hi blokes, quick question, fitting some extra riding lights, where is an easy switched live I can tap in to?, under the seat somewhere would be easiest.
Any tips or suggestions for lights and wiring would be appreciated. 👍👍
MartinW
Administrator
Bike: DL650 K4 Blue
Re: DL1000AL4 switched live feed.
February 23, 2020, 21:19:27 »
Sounds like a job for a Bigpie Fuse Box.
kwackboy
February 23, 2020, 22:00:53 »
Use the live of the rear brake switch connector just In front of your battery under the tank support .
bigpie
Site Donator
Bike: DL650
February 24, 2020, 19:59:19 »
You can get one of these so you don't need to cut the stock wiring
https://www.ebay.co.uk/itm/High-Quality-2-Way-2-8mm-Mini-Electrical-Connector-Kit-Motorbike-Motorcycle-Car/132067645070?epid=0&hash=item1ebfd8568e:g:PtIAAOSw241YfggJ
PM me if you want a 4 way fused relay box for £30
rus998
Bike: DL650XTA L6, Vincent Comet
March 02, 2020, 03:15:27 »
Fit a bigpie fuse box under the fairing for anything fitted to the front of the bike.
grumps
Bike: DL650A M0, BMW R1250RT. Yamaha X-Max 300
Reply #5 on:
July 28, 2022, 14:11:26 »
Same question. Previous owner has fitted heated grips direct to battery. I have just added a Sat Nav holder too but there will be a flat battery at some time😱
I seem to remember fitting a bigpie to my last Vstrom. That”s the answer I guess.?
2020 bike so is the brake switch feed as above still the best way to trigger the relay?
Thanks
AdvntureSi
Bike: DL1000 AL4, Varadero 1000, Bandit 1200, RG250 Gamma MK3
Reply #6 on:
August 10, 2022, 18:31:50 »
Where do we find this electrical marvel of a "bigpie fuse box"?
Seems like it's silly not to look further into this..
grumps
Reply #7 on:
August 10, 2022, 18:36:35 »
Search member Bigpie. PM him.
P24 of members
Barbel Mick
Bike: 800RE
Reply #8 on:
August 10, 2022, 20:13:01 »
bigpie is #3 above. Just click the 'speech bubble' underneath his avatar to PM him.
AdvntureSi
Reply #9 on:
August 11, 2022, 22:42:01 »
Oops.. how did I not fathom that out... Should have gone to Specsavers.......er hold on.. I did....
Pm sent
