Author Topic: Has anyone lowered their V-Strom 250?  (Read 1019 times)
Offline ippikin
  • Bike: DL250 M0
« on: December 13, 2021, 23:58:08 »
Whilst I love my V-Strom 250, being a short-arse I find that I can only touch the balls of my feet either side when stationary. Fine on the flat, but is any uneven ground is involved it can be a little stressful.
Is there an easy way of lowering this bike maybe 20mm or so? Can it be done with "dog bones" or would it mean a new rear suspension spring? Can you get a low-seat option anywhere?
Any advice gratefully received !
Offline V-Twin
  • Bike: Fantic Caballero Deluxe 500
Re: Has anyone lowered their V-Strom 250?
« Reply #1 on: December 14, 2021, 20:39:14 »
Send these blokes an email via ebay and ask them if they have them.
20mm sounds about right.
Business seller information
GB Automotive Products Ltd
Vincent Goosey
6 Pendered Road
Wellingborough
Northamptonshire
NN8 2LT
United Kingdom
Phone:07792529100
Email:vince_goosey@hotmail.com
Don't forget to lower the front as well to suit.
More viewing here....
If in doubt, always get it checked out by a professional.
Offline ippikin
  • Bike: DL250 M0
« Reply #2 on: December 14, 2021, 23:48:55 »
 :ty:
Offline ippikin
  • Bike: DL250 M0
« Reply #3 on: December 18, 2021, 23:08:32 »
Reduced my rear shock preload to minimum and this actually has made a real difference. It was only on setting 3 to start with, no 1. Trying to avoid the potholes though!
« Reply #4 on: December 19, 2021, 06:32:55 »
Out of curiosity, has anyone measured the distance between the bolt holes on the lowering links on a DL250? I was wondering if the DL650 stock links (140mm between bolt hole centres) are longer than the DL250 and thus could be an option to consider for lowering the DL250 suspension. It would also depend on whether the bolt hole diameter is the same.
Offline Whiterose
  • Bike: DL650 K6
« Reply #6 on: June 25, 2022, 08:14:56 »
Any thought of perhaps raising the forks in the triple tree / yoke?   https://www.v-strom.co.uk/smf/index.php?topic=20227.0 and https://www.v-strom.co.uk/smf/index.php?topic=39737.0
