Author Topic: not so smoooooth  (Read 670 times)
Offline bigsimmo
  • Bike: DL1000 K8 in blue / glee in red
not so smoooooth
« on: August 09, 2022, 14:15:45 »
hi blokes.
I have a 2008 DL1000 with 39000 on the clock, it had a new clutch about 2000 miles ago.
now the sob story :old: it has been stood for 10mth due to the fact that I broke my hip :old: now when you go to pull away it judders and wants to jump forward, then not then it does.
it drives OK when moving, but if you try a faster start of it almost like its jumping a tooth on the sprocket, new chain sprockets about 400 miles ago.
any ideas blokes?
thank you all.
steve :old:
Re: not so smoooooth
« Reply #1 on: August 09, 2022, 14:37:43 »
I might be wrong but it sounds like your clutch isn't engaging and disengaging smoothly.
Basically, the steels between the friction plates might be sticking.
Online Upt North
  • Bike: DL650 L7
« Reply #2 on: August 09, 2022, 17:56:21 »
Could it be fuelling with sitting?
Does it make any noise or just feel like it misses a beat?
Upt'North.
Offline Rixington43
  • Bike: DL1000GT K7
« Reply #3 on: August 09, 2022, 18:33:56 »
I'll state the obvious and get the dumb suggestion out of the way but any chance air/moisture has become into the clutch fluid?
Would prevent the clutch from fully disengaging so it would be on the point of skipping and grabbing even with the lever pulled right in. Runs fine when moving as the clutch is then fully engaged with the lever out.
« Reply #4 on: August 09, 2022, 18:37:04 »
Not dumb at all Rixington  :thumb:
Offline bigsimmo
« Reply #5 on: August 10, 2022, 18:12:19 »
thanks so far blokes, it runs fine except for starting off each time, like you say it grabs and judders.
do clutch plates stick? or dry out, good one, as for water it kept in the dry.
thank you blokes.
steve :old:
« Reply #6 on: August 10, 2022, 18:56:04 »
When it jumps, Is there a loud "clonk" sound..?
Sometimes, the steels can get caught on the inner basket and when they release can jolt the bike forward with what sounds like a "clonk" sound, they should move freely.
From your description this was the first thing I thought of , maybe wrong  :shrug:
Offline bigsimmo
« Reply #7 on: August 11, 2022, 17:42:53 »
thanks blokes, I'm going to take the clutch out, anything on the steel's I should look out for?
cheers blokes.
 steve :old:
Offline Dark-Strom
  • Bike: 2018 Ninja 650
« Reply #8 on: August 11, 2022, 17:59:00 »
Totally off the wall but could it be to do with cush drive etc. as I'd expect the judder to be there every gear change if it's the clutch?
Offline bigsimmo
« Reply #9 on: August 11, 2022, 19:20:41 »
hi, new cush last mot, thank you
