There's no problem with the clutch. I fitted a reworked clutch basket from John on this forum who does the modifications to reduce clutch "chudder".
The carbon silencers (which save something like 9kg of weight up high) may be blowing slightly on the link pipes on the videos. I did attend to it later.
The throttles have been balanced and a TRE has been fitted plus a Power Commander and a thorough tuning on the rolling road at Junction 33 in Galgate, which is near my hometown of Morecambe in Lancashire.
It has many other upgrades, such as taper roller head bearings, LOUD air horn, Bigpie fuse boxes and gear indicator, front fork brace, dual headlight relay, Madstad screen adjuster with Vario screen, DRL's, 12 volt socket and another connection for heated gloves, Loobman chain oiler, engine covers, rear sprocket spacer fix, and more.
