Author Topic: Revs not dropping immediately to idle.  (Read 783 times)
Offline Mojo-Jojo
  • Bike: DL1000GT K6
« on: November 14, 2021, 19:18:10 »
Hi all,
Having got my first strom, two weeks ago, the sevice book had a stamp for 01/07/2021.
Not surprisingly, air filter, oil and filter, spark plugs, clutch & brake fluids etc. had not been touched.
I've now done all this, and also used ACF-50, and used the Cymarc kit for lowering the footpegs and the gear change enhancer.
Needless to say, it now feels like a completely different bike, but the revs hover at about 2000rpm before dropping to 1200/1300rpm after about 5 seconds. Is this normal? The throttle rolls off completely.
Thanks in advance.
Re: Revs not dropping immediately to idle.
« Reply #1 on: November 14, 2021, 19:45:37 »
Did your bike have the same symptoms before..? If not, re-check what you've done.
I'm guessing you mat have an air leak ..
Offline Mojo-Jojo
  • Bike: DL1000GT K6
« Reply #2 on: November 14, 2021, 20:18:40 »
Thanks, I'll double check my work, tomorrow. Would that only be on the air intake side?
I didn't really notice if there was an issue before, as I rode home and have not used it until completing this work.
I do have a small leak where the right hand exhaust muffler meets the gasket, which I'll be getting to this week.
« Reply #3 on: November 15, 2021, 06:54:29 »
If the bike engine is cold, then it could the cold start function, which normal operation. However if this happens on a warm engine, then you may have a sticky throttle cable / throttle linkage or a handlebar weight jamming the throttle tube rotation.  Note that the throttle cable does not require lube, due to the special coating on the inside the throttle cable.  https://www.v-strom.co.uk/smf/index.php?topic=32362.0 is a discussion on the Vee but could apply to the Wee.
Offline Lemonwizard
« Reply #4 on: November 15, 2021, 07:32:46 »
We seem to have a different bike, but on my 2012 Glee I recently noticed the revs going up to 2000 for maybe 5 to 15 seconds before dropping to the regular 1300 (give or take a 100). It has started doing this since the air temperatures dropped to below maybe 12°C. Throttle is nice and "loose". I assume this is just the low temp behaviour that's programmed into it?
I like M&Ms - motorcycles and metal 🤘
« Reply #5 on: November 15, 2021, 08:31:42 »
@ Lemonwizard Yes I think they all do that now. At start up my KTM 390 runs 2000 rpm for a while. I am guessing this is to get the catalytic converter up to working temperature to reduce pollution levels.
