www.v-strom.co.uk/shop
Anyone found a bullet proofed way of entering "dealer mode" on the 1050?
Topic: Anyone found a bullet proofed way of entering "dealer mode" on the 1050? (Read 816 times)
bonne
Bike: DL1050 M0
October 18, 2021, 22:17:52 »
I bought a
https://www.aliexpress.com/item/1005002925827150.html?spm=a2g0o.productlist.0.0.23fa2765K4lKsi&algo_pvid=ef37322e-c16b-473b-a457-aae08a5bb0a6&algo_exp_id=ef37322e-c16b-473b-a457-aae08a5bb0a6-1&pdp_ext_f=%7B%22sku_id%22%3A%2212000022833588312%22%7D
and thinking of making the dealer mode plug.
Has anyone found the correct, bullet proofed way of making this switch - I mean without blowing fuses, damaging ECUs, canbus or similar that I have read on the net?
Regards, Lars.
Barbel Mick
Bike: 800RE
Re: Anyone found a bullet proofed way of entering "dealer mode" on the 1050?
October 19, 2021, 09:19:55 »
It's not difficult Bonne (even I made one!) it's just a 'loop' between two connectors.
This thread tells you the connectors ................
https://www.vstrom.info/Smf/index.php/topic,7061.0.html
Although I didn't use a switch, it would be better with one so you can put into dealer mode without removing the seat. This is one you can buy..........
https://smartmoto-electronics.com/waterproof-dealer-mode-switch-dmt-001
If you look at post #9692 here you will see the one I made.............
https://www.v-strom.co.uk/smf/index.php?topic=12233.msg393065#msg393065
Gassoon
Quotes Museum Curator & Moderator
Bike: DL650X L7
October 19, 2021, 17:19:15 »
I don't know about the 1050, Lars, but have you seen
THIS
thread on Stromtrooper?
bonne
Bike: DL1050 M0
October 19, 2021, 17:51:25 »
Yeah, that is one of the threads... Different pins, different regional version, blowing fuses. Would be nice to know exactly how it is done, so I don't fry the brain on the Strom.
Barbel Mick
Bike: 800RE
October 19, 2021, 22:17:28 »
I hadn't realised they changed the dealer mode plug on the 1050.
This thread also goes through the method of making the plug up.
https://www.stromtrooper.com/threads/2020-1050-service-interval-reset.431095/
Reading it, I don't think you'll do anything other than blow a fuse if you get the pins wrong but what do I know?
