Author Topic: Torque on brake pipe flare nut  (Read 715 times)
Offline bonne
  • Bike: DL1050 M0
« on: July 20, 2021, 18:36:50 »
I am torqueing my 1050 for the first time. a few bolts were a little loose compared to the specs in the service manual... But the brake pipe flare nut is easy off. very loose... like it is just turning and turning. I can't see that there should be and lock nut in the back that is spinning with it. Is the 15 nm specified in the service manual correct (like on the picture 2b)
Offline bonne
  • Bike: DL1050 M0
Re: Torque on brake pipe flare nut
« Reply #1 on: July 20, 2021, 19:11:10 »
Sorry... I mean way off. torque is way off on the brake flare nut
« Reply #2 on: July 20, 2021, 19:18:24 »
Is it leaking fluid..?
Offline bonne
  • Bike: DL1050 M0
« Reply #3 on: July 20, 2021, 19:23:42 »
It doesn't seem so - pressure is stable on the pedal
« Reply #4 on: July 20, 2021, 19:55:49 »
Then it's fine ...
A nut and bolt check should have been done on its first service .
There is no reason for a brake line to come loose unless it's tampered with.
