Author Topic: Adjustable span clutch lever  (Read 680 times)
Offline Andyk
  • Bike: 2012 Suzuki V Strom 650
« on: February 19, 2021, 17:27:43 »
 Does anyone know of an adjustable span clutch lever which will fit a 2012 DL650 ?. I would prefer one that is original equipment on another Suzuki model, but would consider recommended after market levers.
Re: Adjustable span clutch lever
« Reply #1 on: February 19, 2021, 18:18:34 »
I'm afraid, as your clutch is cable operated you won't find an OEM clutch lever with a span adjuster.
Your options are eBay for cheap aftermarket CNC brake and clutch levers or, if you want quality, look at pazzo or ASV ..a pair will set you back around £200 ish .
Offline rus998
  • Bike: DL650XTA L6, Vincent Comet
Offline Dave the rave
  • Bike: DL1000 L6
« Reply #3 on: February 21, 2021, 10:14:03 »
I've got same pair on my 2016 1000 had no problems at all did 3500 miles round germany and italy with them :text-bravo:
