Author Topic: Clutch adjustment 2012 650  (Read 1184 times)
Offline Mac1
  • Bike: DL650, Harley Fatboy
« on: December 06, 2020, 13:44:18 »
I had assumed this would be a straightforward task and using a locknut and bolt at one end of the pushrod. Apparently not on later bikes! Why did they make it so difficult I wonder.
Re: Clutch adjustment 2012 650
« Reply #1 on: December 06, 2020, 16:05:03 »
Is your 650 a late registered Wee ..? If it's a 2012 it should be a glee and the clutch,  from memory isn't adjustable at the front sprocket end, only at the lever.
Offline Mac1
« Reply #2 on: December 06, 2020, 16:21:52 »
It is and it is, but you have to drain the oil and the coolant before taking off the right hand cover where the adjuster is.
Offline Joe Rocket
« Reply #3 on: December 06, 2020, 19:50:39 »
Yes, the clutch cover has the water pump on it too.
I assume setting up the clutch at the engine end is really a strip down/rebuild measure. Most cable s t r e t c h problems should be resolved with a new cable, unless the adjustment in the engine is a long way off.  :shrug:
Has your Glee got high mileage?
We used to get new cables often because of breakages which now seems to be a lot rarer.
« Reply #4 on: December 06, 2020, 20:33:13 »
As already asked, has your bike got high mileage ?, there really shouldn't be a need to touch that adjuster unless you have a seriously over stretched cable or replacing the clutch.
Offline Joe Rocket
« Reply #5 on: December 06, 2020, 21:23:09 »
It is of course possible that the friction material on the plates is severely worn down. It you have a worn clutch it would probably be in slip mode and you can't adjust it at the handlebar.
Cable is my guess.
Offline Mac1
« Reply #6 on: December 06, 2020, 22:14:27 »
I just wanted to check it. It has low millage but the clutch lever only pulls in to the bars 80%. It works fine but I just wanted to check the end play. I won't be bothering any time soon. Thanks for the replies
