Author Topic: Cleaning the bike  (Read 885 times)
Offline RederOR
  • Bike: DL650XT
Cleaning the bike
« on: September 16, 2020, 10:31:15 »
Hello,
I suppose this is a very rookie question but how often and how do you clean the bike ? I'm bit afraid of going to pressure self service car wash and spray the front fairing with the foam (I never use brush there) as I think it may be a bit aggressive for bike (but I may be wrong). Perhaps the best way is to take a bucket, some bike dedicated shampoo, sponge and do all myself on the driveway ?
Re: Cleaning the bike
« Reply #1 on: September 16, 2020, 10:38:15 »
If you can do it on the driveway it's probably better. Avoid pressure washers on the electrics and the bearings so a bucket and sponge with a light hose.
The late great Greywolf said he'd read lots of posts he read which started "I washed my bike and now it won't start". I'd recommend at some point lifting the tank and waterproofing the electrical connectors above the radiator.
« Reply #2 on: September 16, 2020, 10:52:16 »
I wash mine pretty much after every outing, unless it's dry then it might go two or three. I don't use it to commute or for work, just pleasure, so it's not too bad.
I use a pressure washer, with the lance turned down to about half, something like hose pressure. I rinse the bike first, then use snow Foam, rinse that off then use a bucket and microfibre sponge/handmit with car shampoo. Rinse it again and dry it off.
I try to point the spray from the pressure washer, mostly, down the bike from the front, in the direction the rain would hit the bike if you were riding in it. Try not to point directly at the wheel bearings or electrics.
I also use a pet dryer to finish the drying off, unless it's a nice hot sunny day then it stands out for an hour or two..............I usually use the pet dryer!!!  lol
Then a polish with Mr. Sheen on the dash & plastics.
Offline user650
« Reply #3 on: September 16, 2020, 11:32:42 »
Wish I had that much time Mick  lol
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline Joe Rocket
« Reply #4 on: September 16, 2020, 11:54:07 »
I hand wash mine with soapy water from a sprayer and the clean water then  a dry duster. No additives to polish.
After a particularly dirty or wet ride I take items off the bike to get properly behind.
If you have a power wash don't point it at the radiator fins/grill (even with a guard fitted) as you will damage them easily.  :grin:
Offline RederOR
  • Bike: DL650XT
« Reply #5 on: September 16, 2020, 13:19:07 »
Thanks All !
I'll stick then with bucket option as it seems to be most safe ;)
Offline bosnjo
  • Bike: DL1000 L7
« Reply #6 on: September 16, 2020, 13:31:01 »
Just as giving it nice finish after washing, I wipe it all with rag soaked in WD40 (general purpose).
WD40 is the best to clean both rims as a single wipe takes off all oil and road residues.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
« Reply #7 on: September 16, 2020, 15:16:25 »
I am retired you know!!  :grin:
Offline old git
« Reply #8 on: September 16, 2020, 18:18:01 »
Once I've washed and dried the bike as best I can,  I like to take it for a short run to help disperse any water stuck in nooks and crannies and dry out the brakes.
Offline Tusker
  • Bike: NO BIKE
« Reply #9 on: September 16, 2020, 18:47:19 »
all good advice,, and I have done this on every bike every year before winter.. It is a proper deep clean and preserve.....      https://allyearbiker.co.uk/
« Reply #10 on: September 16, 2020, 19:47:12 »
I wash mine once a year whether it needs it or not. As for the bike...
