Hello
I have just bought some spots for the bike. These spots are LED U11, and so apparently have low and high beam functions.
But it also means that the wiring is a little different
Each light has 4 wires
Blue - labelled High Beam
White - Low Beam
Green - Ground
Brown - labelled AE DE
so I take it I wire it like this
Green straight to ground (obviously),
Blue direct to the bikes high beam fuse,
White direct to the bikes to the low beam fuse
and then brown to the switch (but which port - or + ) [it must be the - surely?] and then there's the switch itself can I just hook that up to a power outlet from the BigPie I have discovered is fitted. the switch only has 2 wires.
Am I over thinking this?
