From that top pic it looks like either the core is leaking right in the corneror where the core edge is soldered to the end tank has started to let go.
It needs to be run up to temp without the rad guard to see where it's leaking from.
The rest of the area is dry and that part of the rad is wet, so it does look like it's leaking.
