Author Topic: LED upgrade  (Read 1483 times)
Offline ajs193
  • Bike: DL650 V-Strom AL4
LED upgrade
« on: April 16, 2019, 20:06:09 »
I've upgraded my 2014 VStrom's headlights & sidelights to LED bulbs. Not been out at night with it yet but they certainly light up the garage better.
DL-650  AL4
Drift HD Ghost
WANTED - h̶a̶n̶d̶ ̶g̶u̶a̶r̶d̶s̶, c̶r̶a̶s̶h̶ ̶b̶a̶r̶s̶, b̶e̶l̶l̶y̶ ̶p̶a̶n̶
Offline Lincsman
Re: LED upgrade
« Reply #1 on: April 16, 2019, 20:42:22 »
They look good, what bulbs did you get and was any modification needed to the electrical wiring.
Not being too great at electrics, I'm interested in doing the same to my 2016 model.
DO YOU CARE ??
https://www.mag-uk.org/
Offline ajs193
Re: LED upgrade
« Reply #2 on: April 16, 2019, 22:28:00 »
No modifications needed, just a straight swap.  I struggled to get to the sidelights until I figured out how to take out the instrument cluster and it's panel, after that it was easy. Must add that I got the pictured sidelight bulbs from Halfords and they're slightly too long but I've some standard sized Osram ones on order
Headlights
https://www.amazon.co.uk/gp/product/B07FDX33QV/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Sidelights
DL-650  AL4
Drift HD Ghost
Re: LED upgrade
« Reply #3 on: April 17, 2019, 06:05:17 »
How are the beams ? If they are wrong it'll fail an MOT.
Offline sjrainsford
Re: LED upgrade
« Reply #4 on: April 17, 2019, 08:59:01 »
Quote removed
That's kind of a moot point anyway as they should fail the MOT regardless of beam angle.  Many testers of course probably turn a blind eye to them so long as the beam is near enough, but they are not road legal.  The headlamps are designed and aligned internally for Halogen bulbs.  And therefore are E marked for halogen bulbs only.
They do make a welcome difference though  :thumb:
Re: LED upgrade
« Reply #5 on: April 17, 2019, 09:09:22 »
My old eyes are often blinded by bright lights on approaching vehicles. If we all fitted much brighter lights we could maybe all clearly see the light blinded drivers swerving into our path .  I think it's better to slow down at night.
Offline Lincsman
Re: LED upgrade
« Reply #6 on: April 17, 2019, 13:01:17 »
Thanks for that  :thumb:
DO YOU CARE ??
Offline Lincsman
Re: LED upgrade
« Reply #7 on: April 17, 2019, 13:03:24 »
That's an interesting point. I have fitted LED spot lamps to my bike, which are lower down. Never thought about what you've mentioned. Maybe because I didn't know. I do now though. :ty:
DO YOU CARE ??
Offline timangus
  • Global Biker
Re: LED upgrade
« Reply #8 on: April 18, 2019, 07:32:10 »
Fitted same bulbs a year ago to my Strom. One has failed completely and the high beam light is constantly glowing. Also the noise of the fans is annoying. Now in Thailand looking for 55w H4 bulbs in a land of scooters who used 35w items.
Offline ajs193
Re: LED upgrade
« Reply #9 on: April 18, 2019, 14:59:48 »
I wasn't aware of that, I'll keep the original bulbs for MOT time  :thumb:
DL-650  AL4
Drift HD Ghost
Offline joethebike
Re: LED upgrade
« Reply #10 on: April 18, 2019, 23:00:46 »
I put a set of H4 LED bulbs in my 05 650 and they had plenty of light to show you had the lights on but had absolutely no travel compared with the halogen H4s, so they have been consigned to my other bikes which are never ridden at night.
They do a good job though with their white light being very visible in daylight.
1972 Suzuki T350 @180,000km, 1982Honda CX500EC @ 274,400km, 2005 DL650 @150,300km
Offline RoadWarrior1978
  • 6000th Member
  • Bike: DL1000 L9
Re: LED upgrade
« Reply #11 on: April 20, 2019, 10:28:00 »
I have one major concern with converting to LED lights,  that is on a vehicle that has a stator type charging system, excess power is bled off by the Reg/Rec unit in the form of heat.
Trouble is that LEDs use alot less power than Halogen, so that leaves even more power for the Reg/Rec to dissipate,  which means more heat and heat is the biggest enemy of electronics after water.
Might be worth considering for anyone changing over.
Offline Lincsman
Re: LED upgrade
« Reply #12 on: April 20, 2019, 10:42:24 »
Well after reading all the above, I think I'll be a coward and stick to the arrangement I have now.
If I'm honest I don't do that much night riding anymore.
DO YOU CARE ??
Offline vstroman
Re: LED upgrade
« Reply #14 on: April 20, 2019, 13:46:30 »
In my opinion(for what it’s worth)the standard headlights on my Wee are spot on.They are the best on any bike I have ever had,and wouldn’t dream of replacing them.
