Electric contacts
Topic: Electric contacts (Read 1975 times)
pawl
Bike: DL650 L2
Electric contacts
November 06, 2017, 21:45:33 »
Hi just wondering if it is OK to use Lithium grease spray on electric contacts .
Regards Paul.
greywolf
Re: Electric contacts
November 06, 2017, 22:29:22 »
You can, but Lithium grease dries up with time and is hard to clean up. Grease made specifically for electrics would be a better choice.
vstroman
Bike: DL650A L2
November 07, 2017, 01:01:57 »
What should lithium grease be used for?
greywolf
November 07, 2017, 01:16:58 »
I wouldn't use it for anything any more. There are better greases available now.
pawl
Bike: DL650 L2
November 07, 2017, 07:06:00 »
What about spraying the contacts with ACF 50 after cleaning .
UK_Vstrom650
Bike: DL650A L2
Reply #5 on:
November 07, 2017, 07:38:01 »
That would be better. I've put ACF50 in every contact I could get to on my bike
SuzukiSte
Reply #6 on:
November 07, 2017, 11:02:50 »
+1 on ACF50
hotbulb
Bike: DL650 L4
Reply #7 on:
November 07, 2017, 12:41:21 »
.... and on the grease front, you can kill two birds with one stone (or perhaps canister).... Corrosion Block is basically the grease form of ACF 50.
SuzukiSte
Reply #8 on:
November 07, 2017, 21:20:24 »
+1 on what Hotbulb says.
2pac
Bike: DL1000 K2
Reply #9 on:
November 09, 2017, 20:39:30 »
I've used Marine Connector Protector , should keeps things clean and corrosion free if its made for boats , pulled all the plugs apart filled them with this stuff and reconnected , hopefully should prevent any corrosion problems .
Electric contacts
