Author Topic: Air filter swap  (Read 841 times)
Offline Bobbyball
  • Bike: V Strom AK7 Touring
Air filter swap
« on: August 21, 2017, 15:03:01 »
I want to swap my stock fee 650 K7 air filter for the K&N version. Is it worth the extra money for the K&N filter. Is there the power benefits etc. What do you think?
Re: Air filter swap
« Reply #1 on: August 21, 2017, 15:21:16 »
I think the biggest benefit is less need or expense to replace the filter. The K&N will work for longer periods than the stock filter between services and servicing is clean and oil rather than replace. The K&N may flow more air before it gathers some dirt but it also may pass more dirt when it is new or newly cleaned. It's a good idea to put some silicone grease on the bottom of the edge seal, especially at the front, to provide a better dust seal.
For those who fear shortened engine life with a K&N, there is a 2003 DL1000 out there with over 400,000 miles using a K&N air filter, Castrol 10W-40 car oil and Fram oil filters, all things so many warn to be bad ideas.
Re: Air filter swap
« Reply #2 on: August 21, 2017, 21:21:48 »
I also had a k&n filter in my old Cb500 Honda.. I did 40000 miles with it including countless trackdays . I sold it with 100000 miles on the clock and it's still going strong with the new owner (whom I know) with nearly 120000 miles ..
