Wiring in a volt meter
Topic: Wiring in a volt meter (Read 1440 times)
Ian T
Bike: DL650 L3, BMW K75s. Ural 750 outfit.
August 23, 2017, 10:55:58 »
OK I thought this would be simples !!!
Do I wire it in before the battery or after the battery to get the best measure of the voltage.
So where do I go? I know the voltage regulator regulates the voltage from the alternator so is the bit I need to keep an eye on.
So will it be the live from the alternator to the battery and the negative wire to any earth.
If that the case anyone know which one if the wires off the alternator is the live when the engine running. I think there is about four or five.
Or again am I over thinking. Originally I was going to piggy back from the Big Pie four way fuse box I have the spots, heated grips, Sat Nav and USB wired into them and I was thinking of going into double up on the USB one as I know it only live when ignition is on.
Oh yeh the volt meter I have just got has two wires not three as I thought it would be easier
Help please my ed is frying
Ian
Hondaman
Bike: 650 L3
Re: Wiring in a volt meter
August 23, 2017, 11:30:57 »
Absolute accuracy isn't critical.
Ignition switched is good, a feed from bigpies thingy would work well, alternatively, there is a switched live connector on the rhs near the dash that you could tap into for neat installation
Mudster
Bike: Honda PCX125 and DL1000 K3
August 23, 2017, 12:34:49 »
As above, earth lead to a good earth point (or straight to battery) and live to an ignition controlled live.
Don't connect direct to the alternator output as the voltage could be quite high (and likely to blow up an automotive voltmeter) and it's an ac output rather than dc. Needs to be once the alternator supply has been through the regulator/rectifier.
Basically, you are just trying to monitor the battery voltage rather than alternator output.
greywolf
August 23, 2017, 16:48:38 »
#3 at
http://www.vstrom.info/Smf/index.php/topic,1461.0.html
shows some places to get the switched live feed.
Hugh Mungus
Bike: Fazer 1000
August 23, 2017, 21:39:54 »
Once you have connected it to a switched live and confirmed it's actually working the best thing to do is to connect a multi-meter directly to the battery and compare readings. Do this with engine not running, then at tick-over and then at 3,000 rpm and finally 5/6000 rpm. Compare readings at each point.
Don't worry if there is a difference between the meter readings - as long as they are constant. You will know that for example if the fitted voltmeter is 0.5 volts low or high and you take that into account when you're riding along etc.
You only ever need to be concerned if the volts drop very low or go very high.
Ian T
Reply #5 on:
August 24, 2017, 04:27:42 »
Thanks everyone
Fitting this weekend
Ian
