Cheers,
Looks like I've sussed it.
The instructions for clamping the bracket/bridle around the offside of the swingarm are inverted.
When you turn the paper around it makes sense.
Annoying that you need to cut the tab off the bottom of the plastic ABS cover.
Otherwise the tab hits the hugger when the shock compresses.
Will add to this thread once I've got it fitted.
