Hi
Need to change the brake pads on my Glee AL5 and was looking at the spec for EBC Stintered Double H , it states-
Most Double-H pads are fitted (if needed) with stainless steel radiator plates which help in reducing the heat transition into the caliper and brake fluid.
Does anybody know if these pads come with the above mentioned stainless steel radiator plates.
The codes for the pads are FA174HH rear, FA229HH front left and FA231HH front right.
