Author Topic: Where to connect my hot grips  (Read 1122 times)
Offline CHRISHAIGH
  • Bike: 2015 DL1000 AL4, 2016 Indian Scout 1200.
« on: May 27, 2017, 22:34:33 »
Could anyone tell me if there is a spare switched live in the headlight area on the Veek? Just bought some after market heated grips. Thanks.
Offline zippy
Re: Where to connect my hot grips
« Reply #1 on: May 28, 2017, 11:35:24 »
I fitted mine to the power supply where the oem connector is on the bike its best to lift the tank to get to it then you can either use a correct plug or snip the ends of and get your power from there  and you know its fused as well ,if you take a power supply from the headlight area and something blows you don't know what fuse could go and leave you stranded just 2p worths .don't use the aux power supply on the dash as I think it will overload it if used with grips and  gps etc
jason
Offline CHRISHAIGH
« Reply #2 on: May 28, 2017, 12:09:23 »
Thanks Jason, is the OEM plug obvious does the tank hinge at the back then? Thanks, Chris.
Offline SuMo
  • Bike: 2014 DL1000A4
« Reply #3 on: May 28, 2017, 23:16:26 »
The OEM connector is hooked to the same 3Amp fuse as the cockpit 12V output terminal. Check your heated grip manual how many Amps it draws. If you got the Oxford they normally come with a 5Amp fuse.
More info and pic see  - http://www.stromtrooper.com/dl1000a-2014-2016/215961-where-heated-grips-connector-4.html
