Author Topic: Chain and Sprockets  (Read 1744 times)
Offline Tiggerbits
  • Bike: Suzuki GSF600 k2; Suzuki DL650 GTAL0
Chain and Sprockets
« on: November 16, 2016, 11:55:25 »
Hello blokes,
After a little advice/opinions please.
Its time for me to change my change and sprockets, currently OEM and have seen about 22.5k miles (done well I think).
I would like to increase the front sprocket up a tooth, from 15 to 16, as I do about 2000 miles a month and its normally motorway/dual carriageways so thinking it would make it a bit nicer for cruising.
However I'm not sure that I can find a 16 tooth front sprocket that is dampened like the OEM one.
Normally I would pick JT sprockets and a DID Chain. Still will go for a DID Chain, and most likely a JT rear.
Any ideas if I can get a dampened 16 tooth sprocket, or any other suggestions would be great
Thanks
Re: Chain and Sprockets
« Reply #1 on: November 16, 2016, 14:04:49 »
The Suzuki GSX-R600 front sprocket is what you need. Part number  27510-20A10
It is a 16T rubber damped front sprocket that will bolt right on.
Offline Tiggerbits
« Reply #2 on: November 16, 2016, 14:54:33 »
Greywolf, much appreciated!
« Reply #3 on: November 16, 2016, 15:38:50 »
And don't cut the chain until you undo the front sprocket nut.
They are torqued stupidly tight and threadlocked.
Offline Robotstar5
  • Bike: DL650K5
« Reply #4 on: November 16, 2016, 15:42:55 »
On the advice of my local bike mechanic I've fitted a JT chain (and sprockets) as the chain matches the build specs of a DID but is about 75% of the cost.
Offline doboy
  • Bike: 1050 v strom
« Reply #5 on: November 17, 2016, 08:30:34 »
I have put larger front sprockets on the last two of my v stroms ..yes its a bugger to get the std sprocket off as the threads are lock tighten from the factory , however once fitted the bigger sprocket makes a big difference on the motorway and it also makes your speedo accurate instead of 5mph over estimated. .but...while this is a plus when riding solo I felt the bike to be over geared when you have a pillion & luggage , so if you only ride solo + luggage you,ll be fine . On another note I never found any difference in noise from the "non" cushioned sprocket I fitted & had no problems in over 10k..
Offline Faz1966
  • Bike: dl650 2009
« Reply #6 on: November 17, 2016, 12:03:25 »
M&p sell the dampened sproket now.just fitted them to mine front and rear.
