The OEM clutch line is the same as brake lines but last longer as it's not put under the same pressures as brake lines. The only benefits are looks and heat , I noticed when in hot conditions the clutch felt different so I fitted a braided line to my clutch after I reconditioned the slave cylinder and Now the clutch keeps the same feel in hot weather
