Author Topic: GPR exhausts  (Read 3016 times)
Offline Tone
  • Bike: 2020 V, XT 650. 2022 Triumph speed twin 1200. 1953 BSA A10 plunger.
GPR exhausts
« on: May 28, 2016, 09:18:08 »
Hi blokes, I'm thinking about one of these gpr exhaust systems for my glee, has anyone got one? And does it do what it says, give a bit more low to mid range power? And the important thing, sound better!
Offline Tone
Re: GPR exhausts
« Reply #1 on: May 28, 2016, 14:53:30 »
On reading more about after market exhausts, the Fuel ones seem good, have they got the hole for the sensor? If not does it need one?
Offline wurzel
Re: GPR exhausts
« Reply #2 on: May 28, 2016, 19:08:53 »
I'm not familiar with the glee setup, but my fuel end can has been fine, I would give them a call if no one can answer your question, they are good people, I would be surprised if the plug was not on the link pipe, if it replaces the stock pipe where it is fitted.
You will want the O2 sensor on there.
Offline Sam
Re: GPR exhausts
« Reply #3 on: May 28, 2016, 20:48:17 »
Hi Tone,
I had a GPR on my Wee & then a Fuel on my Glee. Only my opinion, but I think the Fuel was the better option. It seemed better built than the GPR & was also cheaper. The screw that held the baffle in on the GPR stripped soon after I got it, whereas on the Fuel it was much more substantial. Both sound much better than the original though.
They both come with the fitting for the lambda sensor - but I think the Wee & the Glee have different size sensors. So long as you order the correct one for your bike it will fit no problem.
If you do go for the Fuel, use the code 'SV-OC' (from the SV owners forum) when ordering as it gives 5% off.
Offline jem58
  • Bike: 2015 white DL650xt, 2011 Honda VT750 Black Spirit, 2001 Honda VT750 Ace
Re: GPR exhausts
« Reply #4 on: May 28, 2016, 22:37:36 »
I've got a GPR system on my Glee and I absolutely love it. It sounds superb mines got the mesh cone in but I don't use the removable baffle. I can't comment on any increase in power 'cos I put it on within two weeks of buying it new and as the bike only had around 400 miles on it,it was still being run in.But it must do something the weight saving is incredible must be nearly half that of the standard unit.
