aye, about the same as the K60's both ends
50 mile review
Turn in is definitely quicker than the Dunlop Roadsmarts, even accounting for new/squared differences. I forgot to take photos, but the front has a rounder profile than both the roadsmarts and the K60's. Rear is 'flatter' than the roadsmarts, but not square at all, the profile just has a bigger radius (poor explanation, sorry)
Dry tarmac grip is more than sufficient in twisties, although technically not as good as the roadsmarts (with the roadsmarts I could get the rear wheel off the ground under heavy braking. The E-07's star to slide just before this happens)
Wet tarmac grip is perfectly fine, I can't tell the difference between damp and dry tarmac (no heavy rain experienced just yet though)
Wet and dry (on tarmac at least) there is more grip with these E-07's than the K60's.
No off-tarmac data yet.
They warm up quick, but when cold they do slide a bit earlier than expected. 2-3 miles into a ride though and they're up to temperature.
Nailing the throttle along wet white lines exhibits no problems, and the tyres don't seem to follow grooves too badly either.
High speeds (closed course, officer) are fine. No wobbling/shaking/wandering evident. Fast cornering is also good. Turn in is fast, but they hold line well. Despite the fast turn in I'd describe them as stable.
Noise.... They howl a little ~30mph (not too bad, but audible), but apart from that I can't hear them. They must be louder than the roadsmarts, but I can't tell any difference above engine and wind noise. The K60's were definitely a lot louder (surprising, as the K60's have a solid central groove on the rear)
They seem to slide quite predictably, even when cold. Easiest way to get them to their limits (as always) is open the throttle too much during cornering. The rear then takes a wider track, but doesn't 'step out' suddenly. Easing off the throttle sees the rear gently return to its original track. During braking, the front grips very well, and only begins to slide just before the rear leaves the ground. I couldn't go further than this with ABS on. ABS activation wasn't as harsh as expected - the tyre must 'let go' very gradually. I'll try tonight with ABS turned off.
Just fitted:Clearance between tyre and mudguard is still good.
Crappy shot of the tread knob profile and guard clearance.
Photos at ~50 miles after fitting:
