Author Topic: Rear disk!  (Read 709 times)
Offline Stromtrooper james
  • Bike: DL650 2011 70K+miles DL1000 2017 12k miles
Rear disk!
« on: September 28, 2014, 14:59:40 »
has anyone ever had any need to replace a rear disk brake disk.
I've been getting thought pads like oneo and now the disk its self has cracks in it and has turned a bit blue.
 any thoughts  on best place to get a replacement?
and how to reduce the amount of wear I'm getting?
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Rear disk!
« Reply #1 on: September 28, 2014, 15:08:31 »
Good used secondhand oem. Use less harsh pads on the rear.
Offline Sharpy
Re: Rear disk!
« Reply #2 on: September 28, 2014, 15:09:06 »
Sounds like the brakes are binding, either the caliper needs stripping and servicing or you are riding the rear brake.
Rear brake pads should last ages, certainly longer than the fronts.  I have never replaced a rear disc, the one on my Vee had done 50k and still had loads of wear left.
Biker & Cyclist...
Online kwackboy
Re: Rear disk!
« Reply #3 on: September 28, 2014, 15:14:44 »
If your rear rotor has cracks replace straight away . Excessive wear is generally down to a worn rear rotor or a seized rear caliper and , some people even ride the rear brake by keeping there right foot on the rear brake pedal without realizing it .
As for replacement , I would recommend nothing other than OEM , although others may disagree .
Offline hookie
Re: Rear disk!
« Reply #4 on: September 28, 2014, 15:15:54 »
If it's turned blue it has been over heating and you need to find out why. The usual reason is due to the piston sticking in the caliper due to build up of dirt or corrosion and/or the caliper slider pins also sticking. It's also likely that the pads will be cooked as well. So all this needs resolving after getting a new disc before putting everything back together.
