Hmmm, just a thought, I had a similar jerkiness before my one cylinder went dead. Turned out it was one of the wires to one of the fuel injectors. There's a crimp connector in the loom that corrodes and causes the problem. I didn't fix the crimp, I bodged it by bridging the wire from the other injector over to the faulty one. I was lucky though, the wire that was faulty was the positive, the negative was fine and it's the negative that gets switched by the ECU, the positive is shared (hence being crimped together elsewhere.) When I tested it I had a lot of trouble finding the fault as it was intermittent.
Not saying this is the fault you have, but it's a possibility to look into if you think it viable.
