Picking your brains here rather than fill up the swear box.
I need to raise the front end of the gear lever slightly on my 2011 Wee to accomodate by shiny new Alt Bergs at a more comfortable angle.
There is what looks like an adjuster....There is a 10mm bolt clamping onto the splined shift shaft...There is a circlip on the gear lever pivot - but which is the easiest way to achieve a "10mm lift" at the front end?
Normal abuse cheerfully accepted in return for some practical advice.
