Author Topic: Aux fusebox  (Read 178463 times)
Offline glenwatt
  • Bike: Tenere 700
Re: Aux fusebox
« Reply #520 on: October 05, 2017, 09:12:48 »
Could I be added to the list please, just bought my latest 07 wee and I'm starting to add bits.
Glen
Growing old is mandatory, growing up is an option !
Offline hambone
  • Bike: DL650 L4
Re: Aux fusebox
« Reply #521 on: October 05, 2017, 11:14:22 »
Hello are you the man for headlight relay wiring? If so do I need it on a 2014 glee. I would like a set. price please plus post to West Yorks. Thanks.
Offline TLPower
Re: Aux fusebox
« Reply #522 on: October 05, 2017, 16:30:34 »
You have a desk?
Impressive.
How are you doing as an entrepreneur, second million yet?
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #523 on: October 05, 2017, 17:08:57 »
Well I do work for my self 5 days per week now instead of the 1, but it's the writing of software that pays the bills. Unfortunately the millions are way off at the moment.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #524 on: October 06, 2017, 20:12:12 »
Next 10 just about ready. Will be going in the post next week. PM me if you want one and I've not already PM'd you.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #525 on: October 09, 2017, 17:40:37 »
3 remaining.
Offline jmee54
  • Bike: DL650 L7, Guzzi 73 Eldorado, 71 Ambasador, 79 Convert
Re: Aux fusebox
« Reply #526 on: October 09, 2017, 20:03:10 »
Not read all of the posts, but this seems to be just the job. If you can tell me where to plug it in on a 2017 DL650 I'll have one. Just pm me your payment details etc.
Offline romeo one
Re: Aux fusebox
« Reply #527 on: October 13, 2017, 08:31:27 »
Could you put me down for one please, PMd you,
Offline Beags
  • Bike: DL650 2015 XT
Re: Aux fusebox
« Reply #528 on: October 20, 2017, 23:03:28 »
Hello bigpie received the fuse box the other day and is now fitted with Cree foglights running off it, its great, delighted with it thanks again.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #529 on: October 21, 2017, 07:08:52 »
Nice one. I'm glad you are happy with it.
Offline Savak
  • Bike: DL650 L7
Re: Aux fusebox
« Reply #530 on: October 21, 2017, 16:08:52 »
Heres where mine is connected on a 2017 650
Offline Freddyfruitbat
  • Bike: BMW R1200RS
Re: Aux fusebox
« Reply #531 on: October 22, 2017, 21:10:25 »
Hello bigpie...
I fitted one of your fuseboxes a few months back - at that point it was just powering my SatNav - and I carefully stashed away the extra connectors you provided, ready for when I'd be installing some heated grips.   Which happened today.
And as you've guessed, I now have no idea where the spare connectors are, so need to source some replacements!  I know bugger all about automotive electrics and don't know if yours are completely standard items - I found these online, are these right?   As in, will they just connect to your existing male and female connectors and sleeves without me having to rewire everything?   If  not - what am I looking for?
http://www.ebay.co.uk/itm/222547061088
Thanks!  :)
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #532 on: October 22, 2017, 21:21:38 »
Those are what you need.
  • Bike: BMW R1200RS
Re: Aux fusebox
« Reply #533 on: October 22, 2017, 22:08:48 »
Thanks Bigpie - ordered.   And countdown timer started for when I find the originals  :roll:
Offline hotbulb
  • Bike: DL650 L4
Re: Aux fusebox
« Reply #534 on: October 24, 2017, 14:59:59 »
Fitted mine today ... piece of cake apart from getting at the trigger (Brakelight) connection under the tank; like others, I'm blessed with shovels not little girlie hands!. But it's done, and the heated grips are working nicely. Auxiliary lighting's next on the agenda, and there are two "proper" feeds now available. Thanks, BigPie, for this useful and well-crafted item.
Offline Tris
  • Bike: V-Strom 1000 K8
Re: Aux fusebox
« Reply #535 on: October 24, 2017, 15:16:29 »
Hotbulb what have you used to fasten the fusebox to the battery tray? I was going to drill through the same place that's all
Offline hotbulb
  • Bike: DL650 L4
Re: Aux fusebox
« Reply #536 on: October 24, 2017, 15:28:23 »
Following someone else's suggesting, having drilled a hole near the base of the tray for the cables to exit I cut, with a sharp knife (carefully!) a slit downfrom the edge to the hole.  To fix the actual fuse/relay unit in place I used a small nut and bolt through another hole , and a couple of "penny" washer to close the slit -  I may try plastic-welding  the slit with a soldering iron later.
  • Bike: BMW R1200RS
Re: Aux fusebox
« Reply #537 on: October 24, 2017, 16:21:31 »
Not wanting to use up precious space in the underseat storage compartment, my BigPieAuxBox sits in the little space immediately in front of the bike's own fusebox, held loosely in position by a cable tie around both.  Not ideal but works...!
Offline Paz324
  • Bike: CB1000RAJ
Re: Aux fusebox
« Reply #538 on: October 30, 2017, 10:42:34 »
Any idea if this fits the new DL1000AL8 ? and how can I order one.
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Aux fusebox
« Reply #539 on: October 30, 2017, 20:04:31 »
You are welcome to try, I can't see why it wouldn't. I was going to keep the last one from this batch to double up on outputs, but I'll let it go if you want it. I'll pm you.
