Author Topic: What size resistor to bypass o2 sensor  (Read 2200 times)
Offline jilljoy
« on: July 06, 2012, 17:36:53 »
Can anyone advise what size resistor I need to bypass the o2 sensor on my k7 vee.I am not going to pay £240 plus for a new sensor(rip off).the dealer has tols me that he will fit a bypass on it but needs to know what size resistor he needs to do it.
Please help
Offline thebigcheese
Re: What size resistor to bypass o2 sensor
« Reply #1 on: July 08, 2012, 09:22:49 »
U not just disconnect the o2 sensor. I did that to my vee and then cut the the correct cable going into the ecu. costs nothing. :grin:
bikeless
Offline jilljoy
« Reply #2 on: July 09, 2012, 21:13:13 »
Dealer says it has to have a resistor on it.he called it a fooler
Offline Ptarmigan
  • Bike: CRF1000 Africa Twin
« Reply #3 on: July 09, 2012, 21:53:48 »
Check this out on Ebay.... http://www.ebay.co.uk/itm/Oxygen-o2-sensor-eliminator-Suzuki-DL-650-V-Strom-07-on-/260961311283?pt=UK_Motorcycle_Parts&hash=item3cc2819a33
Its for a Wee but he may do one for the Vee too......you might still be able to get the Forum discount if its the same bloke, see thread from 2010...
 http://www.v-strom.co.uk/phpBB3/viewtopic.php?f=19&t=5796
« Reply #4 on: July 10, 2012, 12:01:03 »
I got a kit for my vee when I removed the PAIR system (emissions control air valve). inside it was a 10ohm resistor. stops the error code c49 coming up on the dash. ordered it from:
http://www.chewys-stuff.co.uk/ (tabs downleft side - PAIR kit)
bikeless
